GRivera
I have a 30x40x12’ pole barn/work shop with scissor trusses - so center of ceiling is about 14’. The garage door is 8x18’ and insulated. Will be insulated with R38 ceiling, R19 walls. Will also have 2 - 60” 10k cfm ceiling fans. I just want to break chill in winter (60-65 deg) and make it tolerable in summer (78). In Maryland where low temps Dec-Feb can be 32 and high temps Jul-Aug can be 87. I only have a 100 amp panel to also operate a lift (30 amp breaker, large compressor (40 amp breaker).
Ingram’s recommends a 36k unit but it uses a 35 amp breaker and is $1k more than the 24k unit which uses a 25 amp breaker. I don’t mind supplementing with a kerosene heater but hope I don’t have to. If I do, will the Mini split pull moisture out?
