Got an estimate for drywall for my shop and the guy said the drywall would probably crack because the space is not heated and cooled.
Shop will be insulated and I live in middle Georgi. Has anyone experienced much drywall cracking in you shop.
"Probably crack"... based on an "unheated space... in middle Georgia". That's pretty comical!
What exactly is "cracking"? The drywall itself? Or was he referring to joints, corners, etc.?
The drywall itself cracking would be a Red Flag to how it was installed. If it's the joints, inside and outside corners- that's pretty typical in new construction. Framing is as big as it ever will be- when a structure gets "dried in" it starts shrinking- NOT SETTLING. That shrinking causes framing members to move, which in-turn makes the drywall move. That's why you can have "nail-pops" (even screws can have the same effect), small hairline cracks at inside corners and **** joints. Even outside corners with corner bead can move and crack along it's edges.
If this is a standing structure that has several years of exposure- there will be much less movement- but some cracking could still appear.
I think the key is proper installation- glue, screws (in the right places- not the wrong places), board running perpendicular to studs, no joints at door or window corners or headers, etc., etc.
I would almost thing he didn't want the job- and this was his "out".
