will hammerdrill work for 5/8" holes?
PoorOwner
CA
I am trying to drill 4x 5/8" holes in the patio.
I have M18 non-fuel hammer drill, the biggest I have done is 3/8" to mount smaller stuff.
I wanted to know if it would be painful doing 5/8" or not. I would love to have a roto hammer with SDS, but if the little drill will do it then I would save the money.
Also when drilling concrete, is it bad to do the 3/8" first then use a 5/8" bit in 2 steps? As I understand the tip chisel the concrete so would it be counter productive to do in steps like drilling wood or metal.
The Cobbler
I would try it. nothing to lose . in my experience, drilling a pilot hole in concrete doesnt help. in fact it often hinders. perhaps a small say 1/4 pilot hole would help, but I wouldnt go any larger.
P
PoorOwner
CA
forgot to mention, I got time to waste, and the quality of the hole isn't very critical as I am using epoxy to glue threaded rod in.
If I was going to be doing tapcons etc, I would definitely use the better tools to make a precise diameter hole, I found the more struggle I get with drilling the quality and size of hole get enlarged because of all the moving around and struggling.
Parrothead
Earth
My DeWalt 18v did it no problem. I did go through batteries, but the drill did just fine. My arms were tired afterwards, but it was quite a few holes to bolt the machine to the floor.
RAS61
Low Country, SC
A small pilot hole can help a bigger bit from drifting when getting started - provided this kind of accuracy is needed. Doesn't have to be deep or completely through, just enough to get past the "V" tip, then the big bit will track straight
mike93lx
Richmond, VA
Wont be a problem with a good bit.
I recently drilled six 5/8 holes in my foundation with my dewalt 20v hammerdrill. Three were done straight with 5/8 bit and required a lot of effort on my part. Next three were in steps of 1/8 from 1/8 to 5/8. Much less effort on my part and no more time.
NoahG
Detroit, MI
My M18 FUEL did a few 5/8" holes without blinking. I bet the non-FUEL version can do them fine.
patchap
It'll do no problem, just gonna take some time. Be careful and you won't smoke the drill.
Advan
Ontario, Canada
4 holes? Yes, it'll work. Also, a big "NO" to drilling pilot holes in concrete. Save for maybe a dimple to prevent wandering when starting the hole, a pilot is nothing but a waste of time, regardless of the bit size.
Al Borland
No to pilot holes.
Wears the outside ends of the chisel tip and the debris falls down the center and soaks up energy from the hammer action.
5/8" is ambitious with a cordless... but if you have time, and patience you will get there (unless you hit rebar.)
signcrafter
Your drill will do just fine. I would not want to do a bunch of them everyday with it but it will handle a handful without issue. Buy a GOOD bit. No pilot hole. Then just let it eat. Let the bit do the work and don't force it. Pull out and clear the hole often.
I have a dozen or so hammer and SDS drills. Would never drill a 5/8" hole with a hammer drill anymore. Because I have a handfull of different SDS drills that will knock those out in seconds. But 20 years ago I bought my first dewalt 18 volt hammer drill and it drilled plenty of holes that size and smaller for years.
KnurledNut
n/a
I will be the odd guy.
For your epoxy and threaded rod, you will need 4" or more embedment.
I would save your drill from the abuse.
Have you tried a local rental center for a rotary hammer?
Some have very low prices by the hour or 4-hour rental.
They will also have the long bit you need.
I would opt for a sdsMAX or spline hammer.
Also to consider, its beneficial to blow the dust out of the hole and wire brush it, for best adhesion.
I assume the rod is 1/2? I would double check the specs for drill size. It may need 9/16.
PhysicsDude
Dallas, TX
I would do it with the cordless drill. When the holes are on the floor you can put your body weight into it and its not that bad. Its only 4 holes.
I would absolutely blow the dust out of the holes.
Drilling pilot holes in concrete is mostly useless.
reptilezs
i would get a sds drill. i only use my hammer drill on masonry or cinder block
Coach James
Sandhills of North Carolina
I have rotary hammers for holes that size so I can't add much to the drill debate. I will say spend the money on a good bit. I use mostly Bosch bits in my rotary hammers and hammer drills, but I have a few Dewalt and they work fine too. I suspect other brands are good as well. The only bits I have found to be really lousy are Vermont American.
Coach
P
PoorOwner
CA
So here's an update, I burned up the milwaukee after "gnawing" about 1.5" each hole and it's on the way to the repair center now. Probably my fault as I just chucked in an old SDS plus drill bit and seemed kind of dull.
I got a bosch bulldog extreme one and it finished the job with 1 minute drilling 3.5", I was like that's it?? It went down like it was croutons.. I did buy a brand new bit so maybe it's not a fair comparison, but I think the 5/8" bit they are long and heavy and the hammer drill struggled to move the bit. Of course SDS pretty much use a spring to jack hammer itself.
so in the end I think using the hammer drill limit to 3/8" is probably best.. could it maybe do it 5/8" with a brand new bit? maybe, it was very hard on the hammer drill.
6PTsocket
A lot of years ago a buddy wanted to bring up an air line from the compressor in the basement of his commercial garage. I had a pistol grip, corded Milwaukee hammer drill and an 18" masonary bit. I went through 15" of old concrete. The drill was literally smoking. It still works fine today. One thing I found with a hammer drill is that there can be stones in old concrete that the hammet drill can't bust. A few times I also used a star drill and a hammer to break them up and continued with the hammer drill. The SDS stuff was not so readily available as it is today
Miss the Pontiacs
Saskatchewan Canada
I drilled plenty of larger holes with a 18v Bosch drill. Cindercrete, cement or rock a good quality bit will work fine. So can not see why a Milwaukee product couldn’t do it as well. I do have a SDS hammer drill but that would mean I would have to dig it out for a single hole not worth it.
achirdo
Dallas Texas
I drilled a probably 200 3/8 holes with a little dewalt hammer drill. I ended up spending about $200 in drill bits and 12 hours of labor. For the last 20 holes I finally bought a Bosch Bulldog. Finished that last 20 holes in minutes with one bit, and that bit has continued to drill probably 500 holes.
I was so pissed at myself for not getting the correct tool in the beginning.
An SDS rotary hammer is a good tool to have.
Miss the Pontiacs
Saskatchewan Canada
Tough to beat the Bulldog, I didn’t take as long to buy mine. Kind of twisted me a bit (did you catch that) to have to buy all the bits over again. :lol_hitti
