I have a 12' ceilings and after some reading, I decided to go with the 2' LED high bay lights from Home Depot since they surface mount easily to a ceiling box. In using the Visual 3d tool, it called for 9 lights. Since the lights I am using (18K Lumens) are likely to be too bright at times, I will have them on a dimmer.
My building is 28x40 and has a single 18' door on the 28' side. The layout of the first row of lights will have them hitting over the garage door rails (each track and the opener rail). The garage door is not installed yet but I wanted to start wiring. There will be relatively little distance between the bottom of the light and the top of the rail, maybe 10 inches.
Will I get shadows from the rails? I realize I could move the lights 6-8" closer to the wall but I was unsure if that was problematic. As of now, I'm about 55" from the wall and the light in the middle will still be over the opener rail.
