CANned-hAM
- Joined
- Oct 1, 2013
- Messages
- 23
I have a 1.6 HP Kobalt with a 30 gallon tank, 5.3cfm@90psi, 155max psi
The MG725 says it consumes 4.0 CFM at free speed
Don't expect to break any lugnuts with it
5.3 @90psi that's why. it'd br faster to just break them by hand, oh did i mention 5.3@90psi?
First thing, the brand of impact won't make a difference in this at all.
Do you have any first hand evidence of that? Guys run impacts off the smaller compressors all the time. An impact is quite different in duty cycle compared to say a die grinder or other constant air motor.
I'd have to respectfully disagree on that one. The higher end impacts are more efficient compared to the lower cost ones. Thus if someone is on a limited air output a more efficient impact will gain them more usable power.
I do, actually. My ridgid twin stack will not break any lug loose even when it's set at 150psi
I won't argue that point; I would hope an MG725 is using air more efficiently than an Earthquake. But the fact is, they are both, in the real world going to use about the same amount of air.I'd have to respectfully disagree on that one. The higher end impacts are more efficient compared to the lower cost ones. Thus if someone is on a limited air output a more efficient impact will gain them more usable power.
There's something wrong with your impact and/or compressor. Or you are running a really small hose restricting flow. Or your lugs are put on WAY over the torque spec. I have a small dewalt compressor that says 5CFM at 90PSI and it will break lugs all day long.
I agree !There's something wrong with your impact and/or compressor. Or you are running a really small hose restricting flow. Or your lugs are put on WAY over the torque spec.
You aren't holding the trigger of the impact for 10 minutes straight like a sander or die grinder. CFM is a measure of air flow. CFM of a compressor is how much the pump can put out while running. You can have a tank full of air and it will put out as much CFM as your hoses/fittings will allow, with no compressor running.
This was more what I was curious will a house hold type air compressor and regular 3/8" air house with 1/4" fittings net a desirable tank to tool CFM flow to support the 1/2" SO impact
Sent from my SCH-R930 using Tapatalk 2
