Will this hose be OK for LPG?
Vinko
Los Angeles
from McMaster-Carr:
Anyone with any experience in this area?
I'll be using it as a connection for a forklift connection. From LPG filter to carb underneath air cleaner.
robertlynk
California
since you are in LA go to any fork lift repair company and they will sell it to you
cal-lift,Johhnson hyster, clarklift la southwest material handling, the hose man, LA rubber
fatboy99
Indiana
Had one made at the local Parker fitting supplier last week there is hose made just for this application 3 ft hose and 2 fitting's assembled was only $17.00 (check local listing)
V
Vinko
Los Angeles
Why order it from McMaster, when you are in the LA area and have many local places to go for the proper line?
Because if they do have it (and it turns out they do, but I didn't find it when searching the catalog), I'd rather order from them, save time, have it delivered next day for about $5. All done on internet or by telephone w/i 5-10 minutes. Doesn't pay to drive around LA if you can have McMaster deliver something.
WelshWrangler
Make sure its rated and designed for LPG, as LPG will attack and corrode natural rubber and certain compounds.
Sam
rwhite692
Central Valley, CA
That's what I thought.
Fatboy 99 made an excellent point as well, that your local shop would be able to supply you with a proper line w/crimped on hose end fittings, ready to install....Also....For something like an LPG application, I'd want the extra peace of mind that would come from using a hose assembly with the crimped-on hose ends...but that's just me. :)
