will this wiring setup b a problem ???
gilbo
currently my garage lighting is as follows:
finished garage
1 switch, (2)4 lamp t8 fixtures which we call A & B which are mounted more to the back end of the garage.
i want to add (2) more 4 lamp t8 fixtures C & D closer to the front of the garage
is this wiring setup gonna work ????
Switch to A to B to D, and then C wired to A
or does it have to be, switch to A to B to C to D
Steevo
43.49600, -112.04300
A diagram of what you are suggesting would help.
You can easily run 4 or more 4-lamp T8 fixtures off a single switch, but how you do it is that they are all in parallel, with the hot/neutral/ground running from fixture to fixture with each unit grounded and each ballast tied into the hot/neutral (black/white) wires.
lametec
As long as you wire black to black and white to white it'll work fine no matter which fixture is connected to the other. In the end they're all in parallel.
