williamkwong
- Joined
- Sep 24, 2009
- Messages
- 23
Hello everyone! I am getting my garage ready for the painters. I need to replace a lot of the T 1-11 siding because of about 3" of dry rot on the bottom. I want to just replace the bottom portion instead of replacing the whole sheet. This is mostly because I am doing the work myself and the cost.
I searched around the internet for some options and ran into this.
I will basically cut 10" off of the T 1-11. I will replace that 10" with CDX plywood of the same thickness. I will prime and paint all the sides, with careful attention to the exposed bottom edge. I will put a Z flashing between the 2 pieces. Then I will use a 12" tall piece of fiber cement to cover up the CDX and flashing. I will then run a bead of caulk above the fiber cement board to keep water from getting behind it. I will also fill those "holes" that are created with the grooves of the T 1-11 with caulk.
How does that sound? Do I need additional caulking? Can I nail up the CDX with the current vertical studs or do I need to place a horizontal stud where the 2 pieces of siding meet?
Thanks all!
Current
Proposed
Thanks all!
Current
Proposed
