I just moved into a house with one of those tall furnaces that stick out of the wall. It could be 5 years old, it could be 30 years old. I've never seen a heater like this, and I'm trying to figure out if it's behaving as intended...
I'll hear it click on for a minute (warming up?), then the fan will come on and heat will blow out. Early on, the air blows quite hot. Towards the end, it's barely warm at all, as if the hot element the air is blowing over has been "used up".
When it's running "constantly" it runs for a few minutes, then turns off for maybe a minute, then repeats the cycle. During a sunny day it will kick on for a few minutes, then turn off for quite a while until the temp drops again and repeat. Sometimes it will make a rhythmic ping every second for a while...
The thermostat is a White-Rodgers 1F56W-444 mercury unit that appears to be working correctly (turning the furnace on and off to maintain a steady temp), despite being the oldest thing I've ever seen. The pilot/ignition is a Honeywell S8600B.
While it's mostly heating the house adequately, it is definitely struggling at times. More insulation will help, but weather in the teens is common at night for months at a time, so I want to be sure that, if nothing else, the furnace is operating properly. It makes sense that the escaping air would cool down, as it would be less efficient to leave the heat trapped in the element, but...it does seem strange that it runs out of steam, so to speak.
The only reference to thermal control I could find in (what I assume to be) the manual is this bit:
So, am I just eyeballing a perfectly good furnace that is underpowered for the coldest nights of the coldest part of the year in a house that is under insulated, or is there room for improvement by repairing/replacing this furnace?
Protection against overheating is provided by means of a limit
switch located near heating elements, which acts to open relay
circuits controlling the heated elements if circulating air volume
is decreased. The limit switch automatically restores operation
when temperatures reach a normal level. As an additional
safeguard, each heating element is equipped with fuse limiters
to protect against excessive and prolonged current surges. If
these protectors open the heating circuit, the heat limiter must
be replaced by your Service Technician who will determine and
correct the cause of failure.
