Williams socket bit set. Can't decide.
d.mcfarland
Western PA
Hard use or often use? Might want to worry about quick warranty if you're a pro.
Williams USA and import are usually of good quality.
bob15
Northeasten, CT
If you're going to use them all the time, I would pass on that set and piece-meal one together.
Yes, it will cost more, but have better tools in the long run. Perfect example would be buying the gold Snap On torx and metric bits.....they are better/stronger than what that set has. Also with regards to the hex socket bits, buy them without the step in them, as it makes replacing them much easier.
If you are buying them, but not really expecting to use them, then the set should be OK.
