Wilton 350SJ worth restoring?
Rhunes29
I’ve been looking at what I thought was a 450SJ on craigslist for the past 2 months with only 1 blurry photo of a wilton vise that was covered in thick spraypaint and was clearly welded all the way around asking $250.
After bidding on a 450SJ on ebay that ended up selling for over $900, I decided to take a chance on getting to own a rare wilton by offering $200 & hoping for the best as far as seeing if there is any way to remove the welds to get this thing to work like an SJ.
I was slightly disappointed that it’s a 350 not 450, but the swivel jaws seem pretty rare in general. Worst case, the welding can’t be undone and I end up re-welding it but doing a cleaner job of it & end up with an unusual & oversized 3.5” Wilton on a swivel base. (350S?) I’m going to keep it regardless of how it turns out because it’s hard to find any Wilton for $200 nowadays.
That said, any tips or suggestions on trying to remove the welds other than using a grinder, flap discs, dremel & files? Luckily, the welds look really bad & hopefully did not penetrate too deep even though they are pretty thick in some spots.IMG_0790.jpegIMG_0793.jpegIMG_0787.jpeg
merkyworks
Texas
R
Rhunes29
I would think using a bandfile would be very helpfull. Best of luck though
Thank you for the suggestion. I ordered the Wen variable speed and 3M belts. I tried using flap discs on a 4” grinder but it was too aggressive and I did not want to damage the original casting , so I stopped and will try again with the band file. Thanks again.
Fierljeppen
The Wilton 350SJ had the shortest life cycle of all the swivel jaw models, (1958-1966) and is much rarer than the 450SJ. With respect to that, I wouldn't be disappointed at all with your purchase. I think you did well and real well if you can convert it back to a swivel jaw.
Here's a few photo's of the swivel jaw part of the vise, in case they can be of any value toward your endeavor.
1968_GUAR_EXP_63_350SJ_ebay-a02.jpg1968_GUAR_EXP_63_350SJ_ebay-a04.jpg1968_GUAR_EXP_63_350SJ_ebay-a06.jpgwilton_sj_350-a6.jpgwilton_sj_350-a7.jpgwilton_sj_350-a9.jpg
I would consider any Wilton vise "made in USA", including the homeowners models, to command excessive value in the market, with no end in sight.
ecotec
I want to find a cheap swivel jaw with a a swivel base so bad…
R
Rhunes29
Thank you for the photos! They really helped provide reference while trying to separate the 2 parts under the weld.
I made some progress (see pics)
The small section that broke looks identical to someone else who posted a 350SJ & said they bought it that way. The part that broke off is still attached to the jaw, so it might be fixable.
I have 4 Wiltons now & have not done a complete teardown for repaint, but I don’f really have any other choice with this one. I’ve had 2 cans of Hammered Verde Green
from ebay for over a year, so I guess I’ll find out if they’re going to work & still spray.
To prep, I’m planning to wire wheel everything to bare metal and then start to grind/sand the welds to clean up the body & jaw as much as possible. It won’t be perfect, but I don’t want it to look like a hack job either. Thanks again for the advice and pics.
R
Rhunes29
I’ve spent a lot more time working on this than I expected or planned to, but hoping it will be worth the effort. There were so many layers of paint that I had to take the whole thing down to bare metal using different wire wheels, sanding blocks & dremel attachments.
Removing the welds left a really smooth collar/ring around the top of the vise that stood out and didn’t match the rest of the body’s rough cast iron surface texture.
I eventually gave up trying to blend it & prepped for 2 coats of etch primer & several coats of sand-able primer before hammered verde green that I overpaid for on the auction site.
Pretty happy with the results & can’t wait to reassemble. I’ll be out of town this weekend so that will have to wait.
R
Rhunes29
I’ll have to get better pics this weekend, but wanted to show results/reassembled because
I’m pretty happy with how it turned out.
Thanks for having so much great info available on this site. It has been a really great resource during this process.
