Wilton 4" Bullet vise
Slip_Kid
Rhode Island
I found a Wilton 4" Bullet vise on Facebook that I could pass up. It's missing the jaws, has a hole in the round slide. It also has a broken off piece beneath one of the jaws. The main reason I got it was for the swivel base. The base is complete with only a bent handel on one of the hold down nuts. Even with the hole on the tube it works just fine. I need the base for my C1 Vise. Not sure what to do with this vise, maybe put some soft jaws on it. I paid $25 for it, the base alone is worth over $100.PSX_20221112_185540.jpgPSX_20221112_185606.jpgPSX_20221112_185621.jpg
Slip_Kid
Rhode Island
Here's close up of the damage, not sure how to fix it without a welder. Looks like someone tried to repair it, maybe they used JB Weld. It does slide in and out just fine.
Monza Harry
Windsor ON
I'd list the extras that you don't need on eBay/here or the like, as there are parts there that would complete someone else's project even that damaged dynamic jaw, it is better than none or a poorly welded broken jaw. Just food for thought. Harry
Slip_Kid
Rhode Island
I think I can make a good usable vise minus the swivel base I'm using for my C1 vise. I stripped it down to bear metal, other then the damaged slide and some battle scars its in fine shape. All I need is some vise jaws to make it a usable vise. The lead screw is in great shape and it slides in and out just fine. I may use some JB Weld to patch the damaged area.
