Roberts210
I bought this 5-inch Wilton Machinist vise on ebay. Seller said something was wrong with it. The vise was apart, but he didn't know how to fix it. $200. Pickup only. My worthless nephew happened to live in the same city, so I took a chance and sent worthless nephew the $200 (hoped he wouldn't spend on beer and girls) and asked him to pick it up for me. A month goes by and nephew finally shows up with the vise in the bed of his truck, only the dynamic jaw was mounted on the BACK END OF THE VISE. Yes. Dynamic was screwed into where the dust cap should go. The nut was loose, as someone had pulled the pins and they evidently didn't know about how to use an allen wrench to remove the pins--looks like they used an angle grinder to dig out a little around the pins and then pull them out with pliers. Date on the slide is Jan 1970.
So I cleaned it up, primed and painted it and assembled it correctly. I used roll pins in place of the original type solid steel pins. The problem is the handle is hard to turn. If you look at the 2nd picture you can see the round on the handle end of the screw doesn't quite line up with the hole in the dynamic jaw. Now its not as bad as the picture shows, as there is a little wiggle in the screw, but I couldn't lift the handle-end of the screw up, which would shave the clearance down to about half, and take the picture at the same time. I can get the handle to seat into the dynamic jaw, but it takes some pressure to make it go in, and it's a little hard to turn. I can turn the handle with two fingers, but there is resistance. Every other Wilton Machinist vise I've owned you could spin the handle with one finger easy as pie.
So I think the nut must be misaligned just a little bit. But why?
Questions? Comments?
