grimreaperc4
So she was built in July of 1999. I found her in a barn that was falling in. It was moved out of the barn to the grass and was moved via a tractor with a front bucket and was dumped out of it, i believe this is what bent the handle....i believe. So its missing an end cap and has a bent handle.......oh and someone added a few extra bolts. During disasembly it was found out the bolts were holding the center female acme thread in place as it appeared at one time they sheared off the normal pins but the normal pins still are retaining the centralizing piece. Oh by the way thats a pic of the jaw sitting on a 3.5" wilton just for size reference, it is a Big Mother F-ing Vise. I have cut the ends off of the handle and will be using a new 3/4" bar when i replace it as straightening would require more work then replacing, also i am going to try and machine a nice end cap for it if i can get it functioning again. So the big issue, the slide is siezed to the body. I am soaking it with PB blaster but i am soaking it from the rear to the front as it stands like that and not the other way around. Any help or suggestions that have worked for you all in the past. The clearances are tight and i really dont want to put any heat on it unless i have to and i have tried all other options.
