Wilton Bullet made to Swivel!
Ststephen7
Elkins Park, PA
A while back I bought 2 static Wilton 4" bullet vises to restore and sell. One was so beat up I kept it, planning to use it myself.
Then I was given a Morgan 140 that the owner considered scrap since it was missing the screw/handle.
Last night I used the Morgan swivel base to turn my 4" bullet into a swivel vise.
The top of the Morgan base is a little wider than the base of the Wilton, however there is still plenty of support. The Morgan base also has an inner ring for additional support.
The 2 holes in the Wilton lined up perfectly with the hold down ring on the Morgan. However... using just those 2 screws the Wilton wanted to move around on the base... there was nothing to center it.
There was a hole in the bottom center of the Wilton, however the Morgan used a large screw to hold its swivel base onto the upper part of the vise, so that would not work unless I wanted to drill out the 1/2" hole in the Wilton and tap 3/4" threads in it.
Instead I turned a little bushing on my lathe... it is a press fit into the center hole in the Morgan base, and a loose fit in the 1/2" center hole in the Wilton, and works well to keep the Wilton centered on the base.
I also had to make 2 hold downs, plus on additional hold down screw... you'll see in the pictures. I had already used the Morgan hold down on a Parker that was missing that part.
I'm very happy with the way it came out!
Mike W.
I have a Wilton 3-1/2 that I'd love to have a base for....
Sent from my Moto Z (2) using Tapatalk
thehorse13
Jefferson County, WV
If you're handy with an angle grinder you can bevel that ledge and make the swivel base mate up perfectly with the vise body. Ask me how I know. :)
Ststephen7
Elkins Park, PA
Hmmm... I wonder if I can hold the base in my little 10” lathe and get the same result? I probably won’t actually do either...
