This is just an idea here, but could you tap the set screw threads with a grease zerk and use a grease gun with alot of pressure to pump grease into the cavity of the static jaw? Someone else could chime in here and explain if the vise body behind the pipe jaw in the body of the vise is hollow. In the pictures that you have shown, this wouldn't have worked on the pipe jaw in the dynamic section of the vise. But looking at the clearances between the vise body and the pipe jaw in the other picture, they look pretty tight. The grease may build pressure if the cavity is tight enough.
I know this method works, (albeit somewhat modified), for the pilot bushing / bearing in the flywheel. I also know that my Alemite grease gun is specified to be able to develop 10,000 psi of pressure.
This is probably a crack-pot idea here, but I thought it may help. By the way, since this is a Wilton resto - thread, does anyone know if you can buy replacement parts, excluding jaws (both pipe and vise jaws), from Wilton? I was wondering if you could buy, or more specifically where you could buy the vise hold down "clamps" for the swivel base?
Tony
autopts mentioned you can pick up replacement pipe jaws for $100 or less. The vise jaws, a member here was making for people as I recall. Just looked up the thread you can find it
here
there is some significant gaps at each end of the jaw and if I squirt some PB Blaster down the hole I drilled it leaks out around the pipe jaw. I only did this because I had the same idea you suggested... I wanted to see if I could pump it out hydraulically. but I think the pressure would probably just gush out the cavities at each end.
Its also hallow behind that jaw. Have you got any brass stock? If so, place it on that jaw on the top or bottom half and wack it good. That might make it start to pivot. You need to start that jaw moving back and forth. Put your old jaw face to face with it and give the top and bottom a few good wacks. Might need a 16oz or heavier hammer.
I didn't have any brass laying around but I did have te other vise jaw handy. I used my 16 oz ball peen and beat the **** out of it for a couple hours. It now moves, it wobbles a good 1/8" but it doesn't seem to be making any real headway other than that. I did notice that one side is lower than the other. The pipe jaw is not square in the hole and I tried to use that to my advantage and beat on the high side to try and get it to move in multiple planes, but I had no luck.
It does wiggle and I'm not sure if I need to just keep hammering it or if I'm just working against futility. It's currently sitting upright soaking in PB.
I think I'd use cobalt drill bits going forward. Clear out what's left of the set screws. If you have to drill oversize to get them out you can always retap the holes to the next larger size.
If the pipe jaws still won't budge then you might want to drill a hole in them and tap them. Then you could either insert a bolt and tighten it until it hits the back of the casting and it might break the jaw free and pull it out.
You could also use that tapped hole and use a sliding hammer style puller to see if you can get it out.
You'd have to do it in a position where the ridges aren't holding the jaw in.
this set screw has already been drilled oversize in my attempt to get the jaw out.
I'm trying real hard to not damage the pipe jaws since they are in nice condition, but it's always an option. In the end I don't suppose a hole would really affect the jaws clamping ability. For cobalt drill bits I assume your referring to
these? Those pipe jaws are REALLY hard, neither my titanium coated drills or my black oxide will even think about scratching them. Do you drill with the cobalt bits like you would any other bit drilling metal?
drilling the jaws is my last option, but I'd like to have an idea of how to proceed.
so this is where I'm at now. A lot of great ideas, I really appreciate all the suggestions. it ***** that I don't have a nifty picture of a free pipe jaw for this update but I feel a little bit of hope since it started moving. I hope that I can post up some pics of free pipe jaws in the next few days.
As always, all ideas and thoughts are appreciated.
