Wilton model and value
TXNinAZ
Phoenix, AZ
Bought a cheap Columbian and old Wilton the other day and planned on cleaning up the Wilton, new jaw pads and put it to use, and sell or gift the Columbian. I then found a Wilton C-1 bullet, so I'm keeping that instead.
Cleaned most of the grease and surface rust off the Wilton but don't know the model. It's well used and I got it pretty dirty, but really all it needs is paint, new pads, maybe a new swivel clamp, and 5 min on a mill if one wanted the anvil to be perfect. Just one nick out of the iron on one of the jaws in terms of permanent defects. 5" jaws, with about 7 1/2" opening, max. Guesses on what it is and what I could sell it for?
zkling
Welding table vise. $20
O, is that all? :lol:
1982fxr
Phoenix
model 645 utility, i think. if you go on erplacementpartswilton and look at the diagrams under utility vises you might be able to find it...
zkling
Doesn't seem like that much to end up with a solid made in USA vise, but yeah, not everyone sees things the way I do.
Yeah, have you actually done it though? If so what would you charge? The easiest part is milling the anil, provided you have a milling machine....that is if you want to do it properly.
Not trying to harp on you, just so often i see sellers try to convince the unknowing buyers that "all it needs is....".
1982fxr
Phoenix
that anvil looks perfect to me?
I think you can still get new jaw inserts for those @ like $60 or so...
1982fxr
Phoenix
I have one.
It's just a thing that temporarily holds other things.
There's no good or bad.
If you break a vise it means you needed a press instead.
There are very few bad vises, lots of bad operators.
I have to disagree with that part. Most of the (chinese) multi-purpose vises I've seen, as well as bottom of the barrel chinese **** will let go when you start drilling, grinding, etc on the work piece. Annoying at best; dangerous at worst...just my experience.
Also on the cheap-o's, when the body breaks and the handle is still perfectly straight---that is a bad vise. Agree w/everything else you said.
Mark in Indiana
Southern Indiana
TXN,
I've restored and sold a few of these Wilton mechanic's vises. Generally, I pay around $20 for them, unrestored. After I'm finished with them, they sell for $125 to $175, locally. Sounds like your vise would be fairly easy to restore.
Here is a before & after picture of one that I restored, along with making new jaw faces for it:
T
TXNinAZ
Phoenix, AZ
Hopefully now I can get more than $20 out of it. Flipping there jaw pads over made a big difference and if the new owner wants new ones, they're not that expensive, I just didn't want to sink more than the $8 on paint and primer and $2.50 on new socket cap screws for the pads.
davethorik
Norka, Ohio
It's similar to the lighter Columbian models, stamped steel slide. But because it says Wilton, you should do alright.
