So I got a smoking deal on an old Wilton Vise and I want to restore it. I have it mostly taken apart but I cannot figure out how to remove the nut on the inside of the vise. There are two set pins on the outside but only ONE hole on the inside of the vise that's visible. So I thought that I just needed to punch the one out, it would fall, then I'd remove the nut, then punch the second one and remove the end cap. Well currently I cannot punch the one that COULD go all the way through (theoretically) because it's hitting the other wall now and won't give. It is fully through the outer shell but just won't release. I would try hitting it harder but I do NOT want to damage this beauty. The textured side is the outer side. I also can't find anything that talks about this model of vise online so I figured I'd flood you guys with pictures and see if anyone else has a better idea.
