Winalign V9 under XP SP2 not install good
Pathunter
Hello !
Happy to found this forum and good help.I m trying to find similar case but unsuccess.
I have Hunter DSP600 with winAlign V9 (Red key WIN(B) INTL 445-2005V9 and Green Key WEB UPGD INTL 547-3058 V19) on Windows XP system.
Unfortunaly, original computer fail when I try to start Winalign. picture stay stuck on PC and program not start.
We follow procedure 2008-45 who ask to remove some log file and reboot. No change.
I have DVD Winalign V9 built 595 according to my key.(and Aligner Serie 6 from 2016 V7.80 DBZ)
I decide to make new PC Lattitude Dell who can start under Win XP SP2. I put all driver and PC work like a charm.
I'm trying to install Winalign and I can't finalise installation (Still after macromedia flashplayer installation).
I going into folder install and trying to install all software (DirectX, Media player 7, IE5). Some accept and other not.
Anyway, even if I'm start setup program, Winalign install always fail and ask me to reboot.
Someone can help me please?
Regard
P
Pathunter
Hello ! Thanks for your attention.
Setup on DVD => Installing Macromedia Shockwave and Flash Player => searching installed components ......
and windows appair with : Do you want to restart computer now ? (not because loop if I click Yes) and .......
New Windows with in it :
Configuration Winalign : Macromedia Installation failed !
Winalign Installation will abort => ok
and nothing else.
f121
UK
Sounds like a flash problem, which is a component used to build a bunch of terrible apps 15-20 years ago that everyone has abandoned since because of the woeful security issues.
Can you get a newer version of the alignment software?
P
Pathunter
I can download new version but if my key don't match .... it s not efficient ! What must I do ? Hardware is ok , software is here, pc has no problem.... all condition are here for new installation ...
Komet
WA
It sounds like the problem is with that macromedia install failing. You could try looking through the files on the disk to install it separately, maybe right click and install as admin or in a compatibility mode. Try looking at the folder where it's installing files to for a more detailed error log.
Alternatively, try to find the version it's trying to install and find an installer for that online, then bring that installer to the XP machine.
P
Pathunter
Hi everybody,
I follow your instruction and install XP machine with all driver like I say above. I found on disk all program.. I found Flash player without time limitatioon and navigator too for accept this.... I will persist and report
See you soon
P0234
NoVA
Those older programs usually wrote to log files in your temp folder , search by files modified around your last install attempt. Usually there will be clues there.
P
Pathunter
Many thanks for all your advice, I must do a new install and check all program installed (I make picture of my HDD) ..... missing time ....
P
Pathunter
Hello,
I give you some report of my story.
I think I have all for making good installation but not working... I have a lucky for having picture of my disk so I make list from program installed in original PC
I found this:
Framework 1.1 till framework 3.5
Visual C++ 2008 redeistribution x86 9.0.30729
Shockwave
Soapinstall2
And I say ...ok , download them on fresh install and let's go .......install CD after this .......and loosing time, still the same error with shockwave and flash player, winalign stop his own installation .....
So I decide to working on image file from original disk and I see on top of disk : hexlog.txt (around 7 Mo)
and I see in this log that missing one file:
HComQualityDb1.cpp
My program can't acces to is own database because missing this file. I don't fount it on my disk
Someone have this file ??
I can join my file hexlog but I don't want boring help that you give me. (7mo my eyes give blood)
I must say that I have only image disk, computer installed properly and only the blackbox who link the head but I haven't the head connected because I can't put all in my house....just computer and black box linked via USB......
Back to software:
When I see log..... that tell me stopping because missing this file :
HComQualityDb1.cpp
Another problem perhaps is :
ime=2023/04/27.16:13:23 Day=4 TickCount=61484
EventSource="Reserved" EventID=2 Severity=Error ReservedEvent=UnexpectedError
Program="C:\Heprogs\Aligner\EXECUTE\aligner.exe" PID=0x478 TID=0x47c
File=".\HComQualityDb1.cpp"
Line=106
EventInfo={
Could not open database C:\Heprogs\Aligner\qualitydb\qualitydb
Database error code -921 : DBUSERID is already used by someone else
Why perhaps ? because we trying to start program twice and files are locked when they are in use "semaphore"
But sure missing some *.cpp
Please help.
Regard
Komet
WA
Make a blank .txt file and rename it to HComQualityDb1.cpp. There's a slim chance you just need the presence of the file and not the content. At the very least it should change the error message.
39CAMC
St. Louis, MO
I am pretty sure that Hunter has designed their software to specifically not install on non Hunter PC's. I tried one time on a later version (V14) and could not get it to work. Any chance you can get the original PC running, or install the hard drive from the original one in the new computer? I am thinking that if the software were already installed, then there is a very slim chance that if Windows XP can figure out the drivers when you put that original drive in the new box, it *might* work.
DaveW
