winch
csp
Franktown, CO
I have several. One mounted on my CJ5, one on a 4Runner and one on a Polaris ATV all of which are parked in the shop.
Then there are three or four which aren't mounted on any vehicles, but are within the building envelope of the shop. :D
I know, not what you're looking for but I couldn't resist given the open ended nature of the question.
maxpower_hd
Massachusetts
I'm thinking of mounting one with some kind of removable anchors in the floor so I can pull vehicles in by myself. I was looking at a 2500 lb one which I am told might be enough to pull a vehicle on an almost flat surface.
maxpower_hd
Massachusetts
I looked at those pullzalls but I thought 1000 lb wouldn't be enough to pull a full size car or pick-up. Have you had any issues with it? I have other uses at work if that would work in my shop.
greasyfingers01
My buddy has one anchored to the floor under under the workbench that's in front of the lift. He always says it's one of the best things he's added to the shop.
Sent from my SM-N910V using Tapatalk
D45
NW INDIANA
Bought a cool hoist on CL for $60.......1/3 HP and 1,200 capacity
This hoist is bad ***
Even came with the owners manual from 1974
Sealed, Oil bath lubricated motor with actual bearings
The 1/4" cable has seen better days, but that was a simple and easy fix for $20-ish
Lifts 1,200 on a single line
Gear reduction is 533:1
Even has a no slack drum with an electric brake built in
The long controller cable and long 110v plug is also great
joe_padavano
Northern VA
I've got an out-of-production Warn 3200 AC-R. It's great for pulling cars into the shop (up a slight incline) and just moving stuff around.
mnoeltne
Grantsville, UT
I've got two. One is just a manual come-along type winch.
The other is a HF 2500 lb that I bolt to my trailer deck to load non-running cars.
TK-421
Pflugerville, TX
I like the idea of mounting one under the bench by the lift, never would've thought of that but I'll definitely add it to the plans once I win the lottery and can afford my dream shop.
sublimate
Colorado
It'll lift 1,00ft straight up (or so they claim - never tried it).
But It'll roll much more.
I've pulled cars up about a 20 deg incline - it slowed down some, but kept going.
No issues at all pulling my 3/4 ton truck up the ramp onto my lift.
sublimate
Colorado
On my 4-post lift I just wrapped a strap around the front crossbar of the lift and attached the pullzall to that.
