Ray-CA
We already have solar but I am interested in installing a wind generator as well. Since I don’t know much about these systems, I’d be happy to hear your thoughts…
Ray
Ray
And I've never seen one that actually works. The most basic rule of wind turbines is that they need to be well above anything within 500 feet.These vertical turbine are popular now...
you know these things are like solar or wind or hydroelectric etc.... all dependents on location.... so. kinda like if the OP lived in an area that is high wind... he might get it, but if he build a hydroelectric turbine on his creek without enough water flow.... is just the wrong application.And I've never seen one that actually works. The most basic rule of wind turbines is that they need to be well above anything within 500 feet.
These have been quite popular in the past. The declining cost of pv panels has made them less attractive. My brother lives on a 42 foot ketch; he's planning an extensive trip in the south Pacific and perhaps a circumnavigation; he's previously sailed about 20k miles in the Pacific. His boat has 900 watts of solar panels so he can run all the creature comforts including a fridge and freezer (both very efficient built-in units) while far from land.Most all live aboard sailboats have wind turbines/generators to recharge battery banks. They have gotten the design down fairly good…not cheap though.
And, they are on water. HUGE difference in the amount of wind resources available in flat land vs. on ridge, in mountain pass or most of all over open water. Why do you think the North Sea is lousy with them? Also a decent size sailboat has enough mast height to cash in on the near constant oceanic wind. On land you need a really high tower to do that....on a GOOD site, never mind in questionable location with all kinds of buildings to screw up what little boundary layer is moving near the ground.Most all live aboard sailboats have wind turbines/generators to recharge battery banks. They have gotten the design down fairly good…not cheap though. Maybe research those to get some info and system understanding.
Most setups are mounted aft and not high up due to sail interference. Wind resources are variable as in most open places. Most moorings are in bay/on the leeward side of islands and out of trade winds so they are usually calmer. The reason I suggested that OP look at them is for info and research, not necessarily to buy.And, they are on water. HUGE difference in the amount of wind resources available in flat land vs. on ridge, in mountain pass or most of all over open water. Why do you think the North Sea is lousy with them? Also a decent size sailboat has enough mast height to cash in on the near constant oceanic wind. On land you need a really high tower to do that....on a GOOD site, never mind in questionable location with all kinds of buildings to screw up what little boundary layer is moving near the ground.
I got "certified" as an installer on a particular type of wind generator. After spending the money, I decided that I'd never install a wind turbine for a customer. Too much complication, too many moving parts.We already have solar but I am interested in installing a wind generator as well. Since I don’t know much about these systems, I’d be happy to hear your thoughts…
Ray
That's probably 50% for marketing. I bet they might get enough power to run some of the lighting, maybe.For those nay sayers of wind turbine in urban area. About 20 of these vertical turbine were installed on Amazon whole foods in an urban city area and their store are net zero or something… so it must have been working. Don’t know how tall the towers are thought….
Looking at the roof to the left I’d agree with you.That's probably 50% for marketing. I bet they might get enough power to run some of the lighting, maybe.
I bet the roof is covered with solar though
Yes marketing, that carbon credit… it claims 100% runs on green energy with solar and / or wind. That is beside the point right. I dunno if those are 500’ above but it sure works for urban environment better than those propeller wind mills. Not every one needs to install tht gigawatt windmill like the ones in the Lincoln electric.That's probably 50% for marketing. I bet they might get enough power to run some of the lighting, maybe.
Which makes no sense when you factor in that we've got spinning parts in there somewhere that will eventually need some maintenance.That's probably 50% for marketing. I bet they might get enough power to run some of the lighting, maybe.
