rixtrix1
I owe the impetus to go ahead with this project to Falcon67. I noticed he responded on a thread I was reading ( JohnT's "Through the wall A/C recommendations" and when I saw his pics there I also followed his link to his new shop build where he has 2 window units installed in his new shop building, one through the wall. Soon I no longer will be able to use the weather as an excuse for not getting anything done the the garage. After going through a lot of threads I hadn't looked at before, I decided i should stop buying more parts for my Chevelle and start installing/fabricating with those I already had on hand! To facilitate that theory, I went to HD and got an LG 12,000 btu window A/C with heat . It's bigger than the numbers show for my small space, but with the temp and humidity extremes we experience here, I wanted to be covered. I already have the 20a/240v circuit in the garage subpanel. I'll just have to move the outlet nearer to the hole in the wall I'll create to mount the unit. I'm just going to surface mount conduit as drilling a wire hole through a 10" beam with insulation in the wall and ceiling would be too much hassle. After all, it's a workshop/garage and a little "industrial" won't hurt my feelings a bit. Now, getting to both sides of that wall to fab in a hole will take some moving of junk for access, but this is the Small, Messy Carport to Garage. ( Maybe , someday, I'll take the time to figure out posting fullsized pics.)
Note: I'm copying this from my garage thread so the dates are off. I spent part of 2 weekends and an hour one afternoon this week so far and have a couple of hours or so left finishing the trim and paint around the unit.
