Window tint
gjz30075
Roswell, Ga
I've got a normal, 18 x 7 foot garage door with windows going across. What I'd like to do is tint them in such a way that at night, with the lights on in the garage, I can see out but outside can't see in. I've tried the reflective type and works great during the day but reverses at night, ie, outside can see in (with lights on in the garage) but inside can't see out and only a reflection/mirror on the glass. Would simply a dark tint work?
Any suggestions?
zkdiesel
chicagoland cornfields
It's the area that lit vs the dark area that's the problem
Only way people won't see in your windows when it's dark outside and light inside is to pretty much make them non see through each way
NUTTSGT
Northern Central Ohio
Putting the tint on the outside won't make any difference. The problem, as mentioned, is because there is more light on the inside than outside at night.
I'll agree, there's more light on the inside.
I tinted my garage windows with Limo tint but you can still see inside at night with the lights on. I left the blinds in place to prevent people from looking inside and the tint hides those ugly *** cheapo blinds.
What you need to do is add something like a flip down blind or window cover to prevent curious eyes. If you just want to distort their vision and not worried about somebody being able to tell if a light is on in the garage, you can use some stick on frosted window film.
http://www.homedepot.com/p/Artscape...ve-Window-Film-01-0122/100616371?N=5yc1vZarc3
Harley#356
I went through the same thing. I did smoked tint at first, and you could still see in and out (you'd have to be up close against the window to see in, but you could still see in even during the daytime).
I flipped the glass, so the smoked tint was on the outside, and put mirror tint on the inside. Now during the day you can't see inside no matter what, even right against the window. From the inside during the day you can see out, but at night wiht the light on, it looks like a mirror. But from the outside, at night if the lights are on, you can still see in. But I'm not as worried as that as I am during the day someone peeking in, so that works.
nehog
Jaffrey, NH
I don't think this can be done. Vision always follows light so the area with the higher light level will be visible regardless of the type of tint. One way mirrors, and such, are always into a darker room.
G
gjz30075
Roswell, Ga
You guys are right. I tried flipping the tint, ie, using it on the outside of the glass but, no change (same as before).
I do like the frosted window film idea.
Thanks all!
Greg Z
tractordude
WI
I'd go with frosted vinyl.
When I first bought my house, I painted the window on the inside, the same color as the door. It worked for a few years, until I replaced the door.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
There's no way that you will get tint to work the way you want it at night. About the only thing you can do is get blinds and have them pointing down, so you can see directly out, but someone at a distance won't be able to see in due to the angle. The other alternative is to have like mentioned above, a frosted pane, or you would need to have outside security lights. If you have outside security lights, and tinted glass, if the light is pointed in a certain direction against the tinted glass, the light will reflect back and stop someone from seeing in. But even with that, it would still hamper you seeing outside.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
wht about putting thoes decals that they have on cars, which cover the windows, the driver can see out but you can't see in very easily?
:dunno: you mean window tint? :lol:
It's not window tint. It's more like screen door screen that is painted. You see it mostly in pickup trucks and it will have either wilderness scenes or the American Flag.
THat may just work :dunno:
n8n
Curtis Bay, MD
AKA "perforated window graphic film." That might actually work better than tint. I'd try it first before buying a lot...
JakeKohl
Greenville, SC
I work with the stuff - it won't be any different.
There is nothing that will do what you want it to do...even a "one-way-mirror" has to have the blind side dark.
Blinds are your best solution.
black00lightning
TX Hill Country
We have 3 French doors that lead to a patio but we dont use any blinds or curtins so that we can enjoy the view during the day. We installed a dark black security film we purchased at Home Depot for privacy and at night we turn on two large (150w) floods that point at the French doors that in effect create a mirror surface. With the lights on, there is enough image reflections on the outside to make it very difficult to see inside. See almost have to press your nose to the doors to see inside but the outside lights would make anyone doing this very visible. It works for us.
Zeke
"Flip the tint." I busted a gut. Drive by any high rise office building at night and you know who is working late. Those buildings are as energy efficient fenestration wise as anything.
I use the frosted treatment and there's no way you can see inside. So much so that I leave a light on 24/7.
n8n
Curtis Bay, MD
That may be a good solution. Is there a soffit over the garage doors on which you could install lights? Closer to the windows they are the less light you will need.
JakeKohl
Greenville, SC
I should have never said "never". Good thinking!
