winter gear
Tribalvision
Bensalem Pa
you guys working outdoors, What are you wearing?? I'm starting a new job which will have me working outdoors alot. I need clothing recommendations.
What brand is working for you?
What brand do you prefer?
Links?
jackets, gloves, boots, socks, coveralls etc. I will be using my hands alot doing wiring and welding so I cant get too heavy of gloves.
Any help is appreciated.
Steve
JKady
Spanaway, WA
If you're welding I'm going to guess safety toes will be part of the requirement for boots? Stay away from steel if you can. I worked all last winter in steel toes on a concrete floor. Get there at 8, by about 8:45 couldn't feel my toes regardless of the socks I was wearing.
T
Tribalvision
Bensalem Pa
Yeah, I agree. My last job I had steel toe and I couldnt keep them warm even though I was in and out of the cold.
Also, would I need a special bib for welding? maybe fire resistant?
JKady
Spanaway, WA
You might want welding jacket of some kind to toss over your coveralls, but unless I'm doing overhead or laying on my back regular Carhartt stuff has always been fire-resistant enough for me.
richfinn
Leeds, Yorkshire, England
Good warm composite toed insulated waterproof boots.
http://www.jallatte.com/en/products/jallatte-gore-tex/models/288-jalsiberien
I also like O,Neill/Helly Hansen base layers (I,m sure others are just as good) but I can get them cheap at TJ Maxx.
Then layer up with a micro fleece and a Gore-tex shell jacket and pants
Finally get a good hat that is comfortable but not too bulky to fit under a hood (Timberland make a nice fleece hat)
Stick to Black colours and keep the layers thin (so you can move properly)
fury9
Mchenry, IlLaHnoYs
Under Armour compression fit cold gear for the first layer. If you don't get the bottoms the top will creep up on you during the day. I pull my top down and tie the bottoms around it, stays put for about 5 hours. I constantly kneel bend squat climb ladders and such. I used to wear regular ol' long johns for a long time. Switched to the UA a few years ago and couldn't be happier. Still have the same set and the only wear is around the holes where the string goes in on the bottoms. Other than that I just layer up with cotton and top it off with a carhartt heavy weight hoodie. On the really cold days I break out the Carhartt sherpa lined jacket. Get a hat that covers your ears and don't get any type of rubber glove, It will **** the heat right out of your hand. Stick to the leather palmed ones. And get keep an extra change of clothes behind the seat.
T
Tribalvision
Bensalem Pa
I was thinking of getting the overalls, then I can change out my jacket to the environment or what I'm doing. I can switch from a regular jacket to the welding jacket when Im welding, or just a light jacket if its no too cold. I think my torso will be fine with the bib and jacket. What does everyone use for good boots, Gloves etc?
I've switched to flannel lined jeans instead of thermals and single layer jeans for snow hunting and working in the cold. Much more comfortable and warmer as long as you stay dry. Camos for hunting? I have those big enough to pull over the lined jeans.
I use thin cotton "photo" or clean room gloves (Dyed green or brown for hunting) as they give me a lot more dexterity (needed for shooting) and have used fingerless gloves over those at times for working, or just leather & cotton work gloves when doing heavy work or things I didn't need a lot of dexterity. for. The thin cotton glove do wear out fairly fast, and are not good wet (Cold) or for rough work (Wear and tear), so I usually buy them in bulk off Eprey and dye them in bulk for use (unless you want a bunch of static about "white gloves...)
It is amazing how warm those thin cotton gloves keep your hands. Your hands are used to being exposed all the time, so a little protection goes a long way. I've only needed over gloves once in the past 4-6 years up hunting in the cold.
bobcatdan
Kaukauna,WI
Good fitting carhartt bibs. Buy them just big enough to fit over several lawyers. You will get use to them very quickly and hardly notice the bulk. depending on weather I wear my normal shop coat unless it is bitter cold, then I get out the carhartt jacket. I wear lacross iceman boots, not steel toe, but very warm. As for hats, I like my Stormy Kromer. Very warm and it has slide down ear flaps.
mikester
small town NY
I used Carhartt insulated bibs when its real cold. The only problem if theyre made for tall people. I bought the shortest length made and theyre still under my heals and Im 5'8. I tried the coveralls first but they were all too long. What ***** is the side zippers on the legs. You cant have the length shortened. As far as a coat, the artic lined Carhartt with the snapon hood.
As far as shoes I still wear Wolverine 1123s. 6", steel toe and waterproof.
bad_idea
Pasquotank, NC
I dress in layers depending on the weather (in VA it can be 32 one day and 72 the next) and how much I anticipate being outside. Jeans (typically dickies). T-shirt with pocket ($4.99 on sale wherever). Long sleeve shirt from thrift store for $2-$5 (100% cotton for hotwork). Carhartt sweatshirt. Carhartt jacket. Carhartt insulated bibs.
Wear a pair of huge coveralls over all of that if you anticipate getting greasy/dirty. It's a PITA to wash the insulated bibs or coat, but the coveralls are easy. Also less wear and tear on the expensive insulated stuff.
Redwing boots are the only boots I have found that STAY waterproof. I have found for weather above 0 insulated boots are unnecessary. If you are going to be outside all day wear some thick wool socks. Bring a regular pair of socks in case you end up inside though, because your feet will sweat like crazy with the wool indoors.
As far as gloves, my company issues mechanics gloves and leather gloves. I wear whichever suits the task at hand. I find if the rest of my body is warm then thin mechanics gloves are enough to keep my hands warm.
A good stocking cap to pull down over your ears is plenty to keep your head warm. I like the carhartt one I bought 5 years ago.
T
Tribalvision
Bensalem Pa
thanks for all the help so far.. when buying the overalls are they size specific? I'm a 40 waist. Do I buy 40 or go bigger to go over jeans, or do you just wear them alone? I figured if you wear them with jeans and get hot, you can strip them off.
96snma
Calgary ab/saskatoon sk
The under armour cold gear is a life saver. Its all I would wear under my pads playing football up here in canada in -40 celcius playoff games. It's nice that its thin but still keeps you warm. I've had the same pair for 5 seasons and it hasnt broken down on me what so ever.
Sureshot
Bridge Creek, OK
Nice to have a neck warmer as well. Try to keep in the heat you generate. I like bibs with a big hoodie over them and a turtle neck shirt or separate neck warmer. Alot of the heat is lost out the neck and head.
plinker
Northern Wi
I got some thinsulate lined ones form the sportsmans guide a couple years ago, and they are great! Much better then flanel or fleece, IMO. Kinda pricey but well worth it.
Hammell
Canada
If I;m going to be in on a machine for most of the day I;ll set up a tarp with bungy cords, rope and enclose where I am, and turn on the hermen nelson (diesel, karoseen) heater. It actually gets quite warm and a guy can just about work in his tee shirt. Works here for the cold Canadian winters.
JASTECH
Gering, NE
I use bibs and seperate jacket by Dickies, Chipawah boots w/Gortex/Thinsolate, Smart Wool socks (year round). Gloves have been an issue, spent bucks and ordered Yorkshire? or something like that winter gloves. Suppose to be 200gram Thinsolate and about froze my fingers off. I like to wear the knit cotton gloves underneath but I buy XXL gloves most the time, next step is boots on my hands I guess.
Chadwilliam1
Cincinnati
OP what is your job going to be? I use to put up scoreboards year round and when it was really nice out I would get an inside job. I worked in Erie, pa and Cleveland in the winter.
I wore cheap long johns, regular jeans, a long sleeve shirt and a carhartt hoodie. I had carhartt bibs and coat. mine had the detachable hood. I am normally a large but my coat was an xl. my bibs were a bit big to allow me to move. I wore welding gloves all the time but when i was welding I would wear a pair of worn out gloves that were already stiff from being burnt.
I never wore insulated socks or insulated boots. I wore the same type of steel toe redwings for 5 years. Insulated seems like a great idea but they kept my toes Warner longer yes but they also took longer to warm back up and when i was inside for a while my feet would sweat. you do not want your cold feet to sweat.
My leather jacket was big enough to fit over my coat. I welded a lot and I never wore an apron or anything to protect my legs just my jacket. I welde a lot of overhead. the carhartt material is fire resistant but the material around the zipper will melt.
I never had any problems with carhartt products not much is made in the USA and they are priced as they were.
jvitez
Big Sky Country, Canada
+1 on SmartWool socks. I've got several pairs. They're amazing at keeping your feet warm and wicking away sweat, but they are pricey. Otherwise use polypropylene sock liners and cheap wool socks. The liners are fabulous. No blisters! But they don't do anything extra with SmartWool socks.
The best boots I've ever used is the same as our paramedics use in winter: Prospector Forester.
http://jbgoodhue.com/products/professional.php
They're light, comfortable, and warm without making your feet overheat. I really like them.
bad_idea
Pasquotank, NC
Buy the bibs to go over your jeans. Layers is the key. If you end up inside you want to be able to strip some off. Layers also keep the heat in better.
T
Tribalvision
Bensalem Pa
I will be installing, servicing, and upgrading trash compactors and cardboard balers. Some indoors, some outdoors. They will mostly be within 300-400 miles from philadelphia. However, next week w have 15 test upgrades in Cleveland OH.
Sent from my <~ Galaxy SII ~€
Full Throttle
Another vote. Under Armor cold gear is the cats ***. Other than that I buy the walls off branded carhart reproductions for work. I do have charts for non dirty work type functions.
Hammell
Canada
When it gets cold I do have a Stanfield (wool) sweater. Nothing better than that worn under your jacket or coveralls.
mrjaw14
Nashville, TN
Has anyone tried the mechanix wear cold weather (insulated) gloves? Specifically, does the dexterity of mechanix gloves go out the window with their cold weather gloves just like many of the other insulated work gloves?
5lima30
Mountains of Western NC
+1 on the Carhart Bibs! One tip I learned years ago to keep your feet warm is to put deoderant on them before you put you put on your socks. You will be amazed at what a difference it makes!
0.511MeV
One thing I've learned from spending a lot of time in the cold in various locations of the world, is that "cold" can be a lot different depending on the other conditions.
Wet cold is, IMO, the most miserable condition ever. Sleety, icy rain, humid, 25F just feels brutally cold after several hours in it. The constant damp just cuts right through to your soul and crushes your spirit. I'm considering getting some Helly Hansen PVC bibs and jacket for that. Insulated PVC gloves are amazing for that kind of weather. Dry hands are important.
Dry, subzero cold, for me, requires Carhartt Arctic insulated bibs. I shed heat from my torso a lot though, so I like to have less insulation compared to my legs. A sweatshirt will often be sufficient unless I stop for a break. Then I can throw on the insulated parka.
Best long underwear are Icebreaker, IMO. They are merino wool, don't end up smelly like the synthetic stuff does, and can be machine washed easily. The only issue is that they will loosen up and stretch a bit if they get wet and you don't have a chance to wash and dry them that day.
Best socks are Smartwool. I like the ones that go up to my knees. Keep spares readily available in case of wet feet...
Tall boots (8") are better for winter so that cold snow or wetness doesn't get down in them easily.
I haven't yet found a "perfect" hardhat liner (perfection being Icebreaker or Smartwool level of product).
crewchief888
NW indiana
i'm a field service mechanic at a const eq dealership, and can get stuck out in some of the crappiest weather.
regular longjohns
t shirt
long sleeve t shirt or longjohn type
regular workpants
long sleeve work shirt
wool socks
insulated & waterproof hunting boots
insulated "arctic weight" bibs, larger/longer than i really need
mechanics shop jacket, elastic waist & cuffs
watch cap, or baclava
latex disposable gloves
mechanics type gloves or regular brown jersey gloves
i keep a pair of insulated waterproof gloves available.
i try to keep at least one extra pair of socks, 2 or 3 pairs of gloves, and a spare hat in the cab of my truck, and rotate into warm dry gloves as needed.
once the weather turns to sh*t, i dont shut my truck off, unless i'm inside a building
:beer:
RustFarmer
The Rust Belt
Jeans are sized by your circumference where you wear them. Carhartt bibs need to fit over your gut which may be larger than your jean size. Also, bibs can be loose (one of the reasons they are warmer) since the straps hold them up. Wearing tight jeans with a belt underneath defeats the warmth and comfort gained by loose bibs. Try them alone with long underwear, pajama or lounge pants.
I'd guess 46 for you. Carhartts do shrink some.
Start the day with warm dry boots. I have a Peet boot dryer and use it every night. Wool socks, because your feet will sweat, and wool is the only fabric that is still warm when wet. Good idea to have a dry pair of socks to change into for a long day. Wear a hat. If your hands or feet are cold, the problem is usually not enough hat or coat.
There is no bad weather, only bad clothing.
jvitez
+1! I was snowblowing in -30C wearing a snowmobile suit, winter mitts, and Sorel snow boots good to -40C. My feet started to get really cold. I thought "it can't be, these Sorel's are fabulous. Hey, wait, it's -30C." I went inside, put on a down vest, west back outside right away, and in about 10 minutes my feet warmed up.
Yup, I put on a vest to warm up my feet. Core body temp is everything!
BTW, you don't lose more heat through your head than any other exposed part of your body until you're working enough to sweat.
http://www.wintercampers.com/2011/02/19/the-truth-about-heat-loss-through-your-head/
But anyway, cover everything that's exposed.
cheechi
Triad, NC
I spent many winters using "tuxedo" gloves as a musician, the cotton ones both warmer & nicer in general than the polyester ones. if you have a link for what you get i'm interested in seeing those, formal wear stores have had increasingly poor quality gloves in recent years.
FlyBy
NE Ohio
I have a nice worn in carhart work jacket, cut right at the waist and lined, no hood, love it. I also have a good pair of gore-tex boots and hiking shoes, always pays to have warm dry feet.
I get them bulk on Eprey for the best prices
Search for "Cotton Photo Gloves" and you get a lot of hits. They also push them as coin inspection gloves. They also come in a long form, which has it's pluses and minuses.
http://www.ebay.com/itm/12-pair-Cotton-Inspection-Gloves-Coin-Jewelry-Photo-/120491518203?pt=LH_DefaultDomain_0&hash=item1c0ddaa8fb
http://www.ebay.com/itm/24-pair-gloves-white-100-cotton-inspection-glove-men-large-12-long-NIB-/160895960113?pt=LH_DefaultDomain_0&hash=item2576258431
