Diesel Dan
Hooking up power to shop. What I have is the meter base is remote mounted from the building on a pedestal with a 200A disconnect 33' from the panel inside.
We are under the 2008 NEC.
Is the panel considered a main and only needs 3/0,3/0,3/0 of copper or is it a sub panel needing seperate neutral/grounds?
What I have seen in the past and don't assume passes current, or past, code is 3 runs of 3/0 50+ feet from the disconnect to the panel. So it was still considered a main. What that did not have is bare #4 to the main. The #4 was in the meter base and disconnect but stopped there.
If it is a main then do I drag #4 back to the disconnect as well?
Thanks, Dan
Thanks, Dan
