Not to sound rude but who would NOT use the proper color coded wires to a sub panel. Also, something I learned doing my garage. The neutrals and the copper grounds need their own seperate ground/bus bars in the sub panel. Neutral and copper grounds need to be seperated in the sub panel. Also, if the main house has the earth ground rod, and it should, you don't need one on the sub panel. Actually you shouldn't use one as it might create a ground loop. At least this is what my electrician told me as I was wiring my garage sub panel.
