I am working on figuring out what I need to run a 100 amp subpanel in my detached garage. I'm looking for any advice on my current plan and whether or not I need to change anything.
The total length of the run between the main panel and the sub-panel is approximately 185 feet.
I am planning on coming out of the main panel and running approximately 70 feet under the house using SER cable to a junction box on the inside of the block foundation. In the junction box, I would transfer to MHF and run it in conduit underground approximately 115 feet to the detached garage.
Using the southwire calculator, it says for 100 amp at 185 feet I need 2/0 aluminum wire. I was looking at using 2/0-2/0-2/0-1 SER https://www.wireandcableyourway.com/2-0-3-1-ground-ser-aluminum-building-wire and 2/0-2/0-1-4 MHF https://www.wireandcableyourway.com/2-0-2-0-1-4-aluminum-mobile-home-feeder-cable .
Would this wire be the correct size with the smaller neutral and ground? Is there a different type of wire that would work better in my situation?
Also, would 2" conduit be big enough or do I need to go larger?
Thanks for any advice.
