I have an approximately 200’ run from my main circuit breaker to my shop. Approximately 60’ will be through a dry crawl space. I’d like to attach the cable to the floor joists in the crawl space. From the edge of the crawl space to the shop, I’ll be burying the cable in 2” conduit. I plan to have a 90 amp service to the shop. (My home has a 400 amp service entrance so there is more than enough amperage for the shop.)
I think I mistakenly purchased the wrong wire and I can’t return it. I have 250’ of 2 AWG AL XLPE SUN RES 600V TYPE USE-2 ****. It’s a 2-2-2-4 wire.
Am I correct that I can’t run wire this in the crawl space? If so, would you use a junction box on the exterior of the home, splice with Polaris connectors, and then run 2-2-2-4 mobile home feeder wire through the crawl space?
Thank you.
Thank you.
