kartracer55
- Joined
- Jun 21, 2005
- Messages
- 5,317
Wierd. I was going to ask about Channellock crimpers. Anybody use them? I really like other channel lock products and I think they would make a nice addition to my set of pliers.
Waytek is one of my suppliers. I'll have to check out TRC12volt. Thanksmany of the big headache intermittent failures i've had to dg in the past have been due to good and bad solder joints failing. GOOD AND bad ones. the problem isn't the solder, it's the wire. most everything important on a car was designed to survive 100kmi. nothing wire-wire on a car comes from the factory soldered because the joint won't handle the environment.
they all fail. the only thing solder is really good at is pipe and PCB- ideally niether are allowed to flex at all
i've never used it because i do cars not airplanes.
i get crimps bulk from TRC12volt.com and waytekwire.com.
Here's my two Lincoln's worth of advice.Wow! When I asked about crimping technique some months ago, some asked if I was stupid, and implied that crimping was easier than ***.....just do it. Yet I knew that the marine, aviation, and others took this procedure VERY serious.
This thread has not helped the OP much, since it has varied from recommendations of Harbor Freight tools to VERY expensive industrial tools.
What are good crimpers to consider?
Ratchet type: Solid vs. multiple jaws????
Connectors: How about ones that are available over the counter or locally.
Connectors....will these pliar types, and especially the different ratchet types, work with all brands of connectors??? Or, should I use Thomas and Betts connectors with T and B crimpers???? Are crimpers/connectors standardized among brands?
Insulated vs. plain connectors?
Again, is it possible to develop some cook book recommendations here for a handful of affordable brands and basic workable techniques?
I agree with everything you say, but I'd just like to say that, again, NASA uses crimps because of their ease of use in automation, lack of training, and ease of inspection.Hot spit, DMC makes some nice crimpers.
There's no universal answer, but here's my input. A well-soldered connection is an excellent electrical conductor. Really really good. 'Well-soldered', however, means that you have shiny copper, good solder, flux, a clean iron tip, and enough hand-steadiness (or a clamp or something) to not make a cold solder joint (this is what happens when you jiggle or move the connection while it is still semi-liquid). This is not always easy to do, say, under a dashboard. A soldered connector also needs to be properly strain-relieved. When you solder multi-core wire (throw away the solid-core if the thing you are wiring moves or vibrates even a little, it will fatigue on you very quickly) the solder wicks into the strands and stiffens them into a virtual solid core. Where the solder ends, the wire quickly goes from stiff to flexible. This is where any stress on the wire will concentrate, and cause it to fatigue. If you can support the wire past this point (say, with well-fitting cable clamp) you can reduce the vibration and fatigue.
(As an aside, NASA uses a lot of crimped connections on flying equipment for this reason).
I will spend $50 for a ratcheting crimper for the common barrel/spade/etc type connectors. It means that I don't have to worry about the integrity of my connections. Every one is the same as the other, and a manufacturer has figured out how much pressure is required to properly crimp a given size.
Amazingly, I've found that in recent years, less expensive imported irons have come a long way. I used to be a Hakko guy, but no longer. My primary iron for shop use (and ship-board use for delicate work) is an XYTronics 136ESD. http://www.web-tronics.com/esdeltecosos.htmlSharky- I'd be interested in more details of the tools and tech you use. Which crimps do you like? Which soldering iron and solder meets your specs?
All, Thanks for listening. Its an ongoing debate, so if anyone else wants to chime in, feel free.Wow,
Thanks for the info guys. Looks like those ratcheting crimps with replaceable dies is around 120 bucks. I'll have to shop around a bit and see if I can find a sale. Looks like a good pliers is in order too.
Rick
For terminals, check Waytek Wire's catalog, pages 23-25. They have good quality terminals, all available with built-in adhesive shrink insulation.Well, since you asked.
If you could speak to what to look for in terminals for general use i.e. homeowner/auto repair and adhesive lined heat shrink (never heard of that) that would be helpful. I take it that aluminum or untinned copper with solid PVC insulation should be avoided. Are you aware of prepackaged general purpose kits of quality terminals? I have seen the 1000 piece kits for $25.00 but assume quality is an issue.
Thanks![]()
T-Taps have their uses, but nothing permanent.I find this debate interesting, Honestly, I've never once had a problem with a crimped connection I have done "old school" style with pliers. Done hundreds of them and I haven't been around all too long.
As for the shrink wrapped ones, I find that pretty cool, Im going to look into those. Normally if I have to make a connection under a car or under the hood, I crimp as normal, then on each side of the crimp, tightly wrap a band of electrical tape to about the size of the crimp. Once its all even, I wrap over it or use shrink wrap. never had a problem with it.
The worst are Freakin T-taps. THose things ****.
For use in a house, they'll be fine. No water, no salt, no oil, no vibration. They also use solid wire in houses, which I'd never use in a car for any reason.Sharkytm
would you consider these connectors from a reputable company to be inferior:
http://www.idealindustries.com/products/wire_termination/terminals_crimps/
I have to imagine electricians use these all the time in buildings, etc..
Amen, brother. I use electrical tape to tape coils of cable, and to seal the plastic caps on sediment samples. Thats just about it.Up here in the land of salt anything not covered in shrink tube has a life expectancy of about 6 mths.Black tape will not cut it here,hell a heatshrinkable **** connector only lasts about a year or so.My standard practice is a heatshrinkable **** connector covered with another layer of heat shrink tube.Water gets in the blacktape and cant get out,only place I use it is to keep split loom in place over a harness.
The Anchor one is for double-crimps, but it can be used on the single crimps. It'll just put a crimp on the insulation, which doesn't do any good unless there's a sleeve there. I'm pretty sure its the same as the HF one. Seriously. I had an Anchor one for a while, dropped it overboard, and bought the $15 HF one to replace it. Works fine for marine electronics work.This is such a great thread, I never even realized you were supposed to use different shaped crimpers on insulated and non-insulated connectors! I'd always thought those insulated connectors were just impossible to crimp properly. Well no more, thanks to this thread I am reformed.
Couple questions though: What do you pros think of the Ancor double crimper sold at marine supply houses? There's a great thread here where this somwhat obsessive guy compares it to the Harbor Freight ripoff design, it's pretty funny. The Ancor model seems to be compatible mostly with the "double crimped" connectors made by Ancor though, do other companies make connectors that can "double crimp"? Also the Ancor model doesn't seem to have other crimp heads available to fit the frame.
My other question relates to the "Tool Aid" set referred to earlier in this thread. This thing is incredibly cheap compared to a name brand tool. The equivalent Knipex, for example, costs over $200 for just the ratchet frame and the common crimp heads are close to $100 each. I don't think I want to spend $400 to crimp common connectors but I'm just wondering why there's such a huge price difference.
A small butane torch works great if you take your time and keep your distance. With the glue-lined stuff, you have to start in the middle, and work your way out. You also need to rotate the wire or the torch around the wire so the adhesive melts evenly and flows into every cavity. You'll know your doing it right because as you approach the ends of the tube with the torch, glue will ooze out. Thats a good thing!Sharkytm,
Helpful last post. I am putting together an order from Waytek for some terminals and dual wall as well as the Tool Aid 18920 from Amazon, but, one more question. What would you recommend for a basic heat source for the tubing?
Thanks again.
Its like comparing a Jeep to a HMMV.Its like comparing a Hyundai to a Mercedes. Knipex also has all the certifications that may be engineered spec on certain jobs.
Liquid electrical tape is OK, but its messy, stinks, and is flammable before its dry. I've use it before. It also peels off easily, which doesn't make me feel all warm and fuzzy about it.This is a really good thread with lots of tech talk. I'll have to re-read a couple of times. I am expecting my first pair of ratcheting crimpers this month once the Toptul order comes in; if this post is still alive when I get them I will report back about them. Also, it seems I am the only one who has used liquid electrical tape to waterproof thier marine connections. That's usually not a good sign. Never used it before so I thought I would try it because the heat shrink **** connecters were ridiculously expensive. I replaced two bilge and two ariator pumps last spring. I'll check em this spring to see if their brittle or flaking after one year.
What did that package run you? $500 or more I'm guessing. Thats a hell of a set, and I'd love to have one.Complete solution for many splice applications. I´ve bought this kit from Rennsteig at the AAPEX Show in Vegas.
I've had both Klein and ChannelLock crimpers. Both are good, and I'm not convinced that they aren't made in the same factory.Still have to do more research but I put these in my Amazon shopping cart:
http://www.amazon.com/exec/obidos/t..._shr?_encoding=UTF8&m=A3RNIK5KD9N594&v=glance
Or is the Kline better?
http://www.amazon.com/exec/obidos/t...t_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
And this:
RickP
Waytek sells upsizing crimps and other stuff like that.Anybody used Hydralink connectors? They have some that are blue on one end, and red or yellow on the other to make it easy to use different size wires or multiples.
They look similar, but the Paladin set doesn't have the other jaws.Has anyone tried the Toptul kit http://www.toptul.com/ part # GAA10605. I checked Mike's site and he has it listed for $88.55 less his GJ 20% discount would make it $70.84 plus a few bucks shipping. I was wondering how it stacks up to the Tool Aid kit that Amazon has for about the same price.
They both look similar but not identical so one may be better built or designed than the other.
That toptul looks nice, but reminds me of my HF crimper, even the E-clips on the pivot pins. The correct part number is GAAI0605 , its an "I" not a "1".
For what its worth... I have mainly used the 959 model for quite some time now...
Does the mac have additional dies that come with it too?
RickP
Wait a week, I have one on the way and will let you know what I think when it arrives.I have the tool aid crimper in my amazon shopping cart right now, I know it's not the best out there. But it seems like a good deal? I think I'll just bite the bullet and order it.
...but for most things, solder and 2 layers of glue-lined heatshrink is better than any crimp.
Adhesive heat shrink is the bomb.![]()
The Tool Aid ratcheting crimping kit came in today. Previously I had only used non-ratcheting crimpers for insulated and non-insulated terminals, sometimes maybe just a pair of dikes for the crimp. The results were sometimes uneven and not always secure.Roger that, I look forward to a review!![]()
The Tool Aid ratcheting crimping kit ...
... but for $81.42 delivered from Amazon, it works for me and seems a good value. No indication on the tool about where it was made.![]()
