Wire Rope for a shelf base
pdude
San Jose, California
Anyone make a shelf base out of wire rope? Have already hanged some shelves from all threads in the ceiling. I would like to create the shelves to have a mesh base (i.e. instead of plywood as the base of the shelves).
Local Home Depot has coated welded wire which is too weak which is why I'm looking to just use wire rope to create the base.
maxpat82
I have used laced steel rod to make stuff like shelves, but can't find the real name of that thing. (I'ved been given the "bent" steel rod and laced them myself.) :|
it's very sturdy....not sure how actual rope would do (been tightening them will be hard and can't easily weld multi wire cable)
edit: found it:
search for : Crimped wire mesh.
http://french.weld-wiremesh.com/pho...wire_mesh_for_making_barbecue_metal_grill.jpg
GMCGarage
Wire rope is not stiff enough, unless you can tension it. I would use some screening or gating material.
LeeG
Phoenix, AZ
Would expanded sheet metal work for you? It needs to be supported at the edges, but would make decent shelving.
maxpat82
expanded metal will be way cheaper then any form of wire rope or cable.
P
pdude
Btw, I'm not aware of a load rating for this material? I did a quick search and didn't see any data on most sites. I might have to ask each manufacturer.
Sent from my SM-G892A using Tapatalk
samss
Conway, AR
Maybe a frame made from unistrut and the coated cable/wire laced like old style lawn chair webbing?
P
pdude
That was sort of my original plan with using wire rope. Then using clamps or crimps to keep it tight. Two posters mentioned some possible issues with that plan which I'm still considering that as an option.
matt_i
You could use woven bike wheel spokes and tension them with the little round T-nuts.
Wire rope could work but you'd need many rounded "guides" and maybe some drops of oil to lubricate it and get the stiction out. Somewhere there would have to be a turnbuckle-type tensioner with a fair amount of takeup.
P
pdude
On one shelf that was against a wall I had just cut crossbars of half-deep unistrut that worked. But for this other shelf that is just dropped from the ceiling, thought about using allthreads as crossbars. I see they are rated at 600# or more, but that's holding it from end to end. If I use them as crossbars to build the shelf based is there a way to determine what load they could handle?
