Wire Shelving replacement collars/clips - need help!
FTG-05
TN
I got a bunch of free wire shelving that as being surplused by the local Cracker Barrel restaurant. since a bunch of it was in the cleaning room, some of it was pretty nasty plus covered in grease. A pressure washer took care of the grease but the plastic collars/clips need to be replaced.
I can find the round replacement clips all day long. What I have, however, are the ~1" square shelf poles.
I've found exactly one source; it's on Amazon and they want $34 for four collars!
Here's a pic of what I need:
And here's the Amazon page: https://www.amazon.com/dp/B00N2USENU/?tag=atomicindus08-20
Anyone have a better (and cheaper) source?
Thanks,
gungatim
west mich
drill holes in the columns and use some bolts or rods...or maybe make some wood wedges from cedar shims?
gregtwojeeps
Ky
Check out your local used restaurant equipment supply stores as they carry a lot of wire shelf racks/stands. They may have some for sale ...maybe.
kabinenroller
S.E. Wisconsin USA
All shelving has a name stamped on each shelf, the stuff you have looks to be Amco brand. You should be able to locate the collars from the local restaurant supply or just contact the company. If there is a used equipment dealer in your area they might be able to help you.
F
FTG-05
TN
I have both SPG and the AMCO brand. I e-mailed SPG this morning, no joy as yet. I see that someone posted the AMCO link below. Off to order, thanks!!!
