Hello,
I've got a detached shop that I'm trying to get wired up. Here's what I know so far:
House has 400A total and was pre-wired with a 200A service to feed the shop (see photo)
I've got a 2" (Inside Diameter measurement) conduit running between the house and the shop.
I've measured the string and I'm going to need 90' of wire to connect the house panel to the shop panel.
The shop has a ground lug already installed in the foundation.
I've bought the breaker panel and all the boxes, wire, etc. for the shop so once I get the feeder wire in there I'm ready to get started.
I've got a permit and I plan to have an Electrician help me with the actual connecting of all the wires.
Can I get some help with a recommendation on the wires I need to run between the house and the shop? Please understand I've got very little knowledge in this arena. Based on what I see in the picture I'm looking at running 2 large insulated wires (probably aluminum wire I assume?) Do I also need to run a ground wire?
Thanks much!
Thanks much!
