z28toz06
I am doing my wiring now and I am locating my compressor about 50 feet from the panel. it will be a 220 volt 5 horsepower unit (don't know which one yet) is 10-3 wire big enough?
So what about the start up draw ? I know we have been through this many times but ,
Not sure on the 28 amp 5 hp motor but my 7.5hp motor is at 33 running amp and the start up draw is around 76 amps ! Thus the reason i installed a #4 wire on mine and an 80 amp breaker.
I would think for the 5hp unit i would run at least # 6-2 wire and a 60 amp breaker. The compressor will work on less but we know what happens with lack of wire on electric motors ..............![]()
You should be able to up the breaker size WITHOUT upping the wire size if in fact you are having nuisance tripping. You shouldn't need #6 for a 5hp unit unless the motor is far away from the panel.
BTW ,
I wouldnt put an oversized breaker on an undersized wire, Dont think thats a good idea.
If you elect to install a subpanel at the compressor (other circuits in this area could be handy) you also would need to carry a neutral to the subpanel.
It's allowed, by code, for certain things like a compressor on a dedicated circuit.
) The start-up spike doesn't last long enough to over heat the wire, thats why you don't have to size the wire for the spike.
The code does allow for a larger size breaker:
Table 430.52
Maximum Rating or Setting of Motor Branch-Circuit Short-Circuit and Ground-Fault Protective Devices
Single-phase motors- "Inverse Time Breaker" 250% of full load current
28amps X 2.5= 70 amp breaker maximum
Mark
What he said.The start-up spike doesn't last long enough to over heat the wire, thats why you don't have to size the wire for the spike.
Table 430.52
Mark
Remember, the breakers and the wire is not going to go up in smoke if you go over the normal specs for a short period of time. There is a lot of safety built into the components.
Maybe if the run of wire was very short, would the price differential be neglible. All I know is with the price of copper and the lengths I would need, bumping up to the next size wire wouldn't be worth it.
Maybe if someone has the code listing for the amount of A a wire can take for a short period of time...I know I've seen the chart before. Might make it a little easier to see/understand.
Here you go:
#12 wire = 20 amp breaker 16 amp load max
# 10 wire =30 amp breaker 24 amp load max
# 8 wire = 50 amp breaker 40 amp load max
# 6 wire = 60 amp breaker 48 amp load max
Matt Murphy
