HoosierBuddy
Hey guys,
I was swapping out the aftermarket stereo in one of my old cars last night. Luckily I still had the old manual that had the wiring color codes for the old Sony and (surprisingly) the new JVC's color codes are exactly the same, so it was as simple as snipping off the connector on the old stereo and splicing in 11 wires to the new main connector.
Of course you're dealing with wires in the car, under the dash...so not a lot of room.
I've always just stripped back 1/2" insulation on each wire, split the strands down the middle on the two wires to be connected and push them together and then twist the strands, then use a soldering pencil and low-temp solder and then slide a heat shrink tube over the joint and heat that up with a lighter.
It's just really slow to do it that way. I'm wondering if there's a better way and if so what you guys would do in the same situation?
Phil
Phil
