Michael Bryce Winnick
- Joined
- Jan 25, 2010
- Messages
- 112
What is the best wire stripper for light commercial duty that is American made?
I use these every day as an electrician
View media item 4686
There easier to get replaced than Kliens and when you cut and strip as much as i do you were out a pair pretty fast and I'm pretty sure there made by klien for craftsman and cheaper to
I also have the craftsman branded knipex cobras cheaper than the knipex brand with a better handle
It depends on what you're trying to strip.
I primarily do electrical and electronic assembly and would be miserable without these old Ideal StripMasters I got from my dad.
But I carry more basic strippers in my road kits, and use Kleins for romex and thhn when I'm doing house wiring.
times two found a pair on the ground near an edison plant in the desert (go figure) and a little wd-40 and they strip it perfect every time. same type ony it says blue point on the back.
I like the 'automatic' style for wires with soft and flexible insulation such as in cars...
http://www.amazon.com/dp/B0002KR95W/?tag=atomicindus08-20http://www.amazon.com/Irwin-Industr...ref=sr_1_1?ie=UTF8&s=hi&qid=1275319011&sr=8-1
and for household repairs for solid wires with hard slippery pvc insulation:
http://www.amazon.com/dp/B000OQ21CA/?tag=atomicindus08-20http://www.amazon.com/Automatic-Wir...ref=sr_1_9?ie=UTF8&s=hi&qid=1275319011&sr=8-9
I'm not sure if they are made in US, or any kind of strippers in that matter...
but for most wiring repairs on cars i use the trusty Channellock 909, unless it's a real heavy battery/starter cable or a high gauge ultra flexible with fine strands (like the ones used on with hall-effect wheel speed sensors on GMs) i use the cutters to strip the wire...
http://www.amazon.com/dp/B00004SBDI/?tag=atomicindus08-20
