Take a tie or two and tie them in a bundle, pull pull one out as needed.
X2^^
I just leave them in the bags that came with them. I cut a small (about an inch) hole at the top of the bag to dispense them.
Even better to improve on this suggestion: cut a slit in the middle of the bag. You can still reach in and get one, but they won't fall out the end on their own.
Slightly off this topic.
Has any one seen a special type of zip tie that is designed to be used to clamp rubber and vinyl hoses ? It forms a complete circle when cinched down. I heard some outboard manufacturer (Evinrude ?) uses them and they are just as good as worm gear clamps for most applications (obviously not high pressure).
I would sure like to get some to use on small engine fuel hose (typically vacuum).
I have seen those, but not really what I was thinking of. But the did lead me to the right placeThey call them snapper clamps. Any marine place should have them. Probably cheaper to get online. Anything with marine in the name goes for double price.
The clamp tie has triangular shaped tabs extending beneath the head, allowing for optimal surface contact and complete circumfrential compression to 360 degrees.
The clamps are recommended for soft rubber hose applications including fuel, water, and air vacuum lines.
