Wired thermostat for LG Ceiling Cassette
gansh62
I was wondering if anybody out there has installed a wired thermostat for LG brand ceiling cassettes. The thermostat wire for the thermostat came with pre-installed quick connects, but I can't find the associated quick connect port on the cassette, and LG tech support is horrible. I will have to remove the quick connect on the thermostat side, but want to make the proper connection on the cassette.
gmcgeo
You need to purchase the jumper cable. but here see if this helps you
chinboys
Why?, Don't like losing the remotes or replacing their batteries?
I have 3 of these ceiling cassettes and once had a notion to do the same.
I have Nest and Ecobee smart wifi thermostats and thought about using them for cooling too for each room my cassettes are located in.
LG makes an interface to each cassette at
LG - Smart AC Wi-Fi Module​
where it costs $110.00 for you to use their app on your smartphone to control.
I'll keep on looking as the 4 wires (power, ground, and two signal wires) might be able to work with a thermostat.
cheers
Went to my supplier and found something you can use...
CRC2 MultiSite Remote Controller​
$244.99 each
G
gansh62
Thanks guys!! Chinboys, yours is extremely helpful. I know were this connection port is in the cassette. I will have to remove the quick connects for both the cassette and thermostat, but this is not a problem. I have 4 cassettes and will install 3 hard wired thermostats (2 cassettes ganged). I find the sensor on the unit reads 10 degrees higher than the actual room temperature and hope that the hard wired thermostats will have the units run more effectively/efficiently. I did install remotes on all. This system is running on a 2nd vacation home and this allows me to control each unit remotely...I love them!! Thanks again for the support!!
