wireing 220-1ph 5hp Baldor
southbend
s.w.wash.
HI i am southbend HI there I am not sure how to use the Garage . so here goes I have a southbend lathe with reverser switch .the switch has W for manf.cant read the rests style:10329. type:n140 it has 2 rows of 3 for 6 wires .the 220.5hp.1ph. Baldor has 4 wires.the diagram shows( 5 _8)on top. (1_4)on botom .trade 5--8 to reverseit .it blows the braker when tried it. need to fix wiring problem??? thanks
RPH
Michigan Thumb
Was the lathe orginally wired for a three phase motor. If so, this switch may not handle the current load for the single phase. When I converterd my Rockwell over from three phase to single phase I used the switch to operate a reversing contactor for the motor.
Verify the contact current capacity first. If it will handle use your multi meter to ring out the various contacts and find the short.
southbend
s.w.wash.
hi RPH its 1ph it had a 2hp 110-220 in it you may be right about the short. Iwill test the wires. and try it . I need somthing to do in a wheel chair in my shop .a ladder got me and broke my foot when I was runing wire to it. down for 8 weeks thanks
