Wireless Internet to Detached Garage
dprintz
Philadelphia Suburbs
Forgive me didnt see anything in the search
I have run an ethernet cable to the garage from the FIOS router. How do I get wireless in the garage now?
Thanks
Jbullfrog
Avoca, Iowa
Buy a wireless router for the garage and connect it to the cat 5. Connect the cat 5 in the house to your existing router and configure it.
LB-1911
Northwestern Il.
Thanks
Might be of assistance to you or others that stumble upon it later -
School me on Ethernet splitting
http://www.garagejournal.com/forum/showthread.php?t=273714
Wifi to Garage that is 450' from house
http://www.garagejournal.com/forum/showthread.php?p=4486421
Extending WiFi to detached garage
http://www.garagejournal.com/forum/showthread.php?t=141302
Good Luck
:beer:
Denwood
Thunder Bay, Ontario, Canada
If you only plan on using WIFI in your shop, it will be simpler to just plug a wireless access point as below into your cable. It also provides a power over ethernet "injector" effective for 100ft that you would install at the house side. This way the device can be mounted up high, with no worries on power. The power is provided over the ethernet cable. My preference (worked for the feds for 10 yrs as a system's analyst) is to use a dedicated WAP (wireless access point) as opposed to messing with a 2nd router. In cases where you have to reset a router, the conflicting DHCP on the LAN side etc. just creates more hassles.
This one is only $50 with a POE power injector :)
http://www.staples.ca/en/TP-LINK-30...-Point-TL-WA901ND/product_169124_2-CA_1_20001
nolimits76
Oklahoma
Agree w/ Denwood on the WAP.
I'm doing something similar inside the house. In my case, I originally preferred a hard wired connection for all my media devices (Xbox, Bluray, DirecTV, etc). The simple solution was to drop a new line down the wall. I tried that. Problem was I had cross bracing between the studs. That combined with french vault ceilings and consequently high walls resulted in a mess. Had a couple of companies decline to even try the job. One electrician said he could get it but it was more $$ than I wanted to spend.
Alternatively, I picked up an Apple Airport express and set it up as a WAP. I now run an ethernet connection to a Netgear switch and run ethernet cables to my various devices.
I caught the Apple device on sale - around $80 as I recall. I already had the switch from a previous install when I lived elsewhere and could drop a hard line, but that was about $30.
By default the Apple device will run as a router but like most Apple products, it's easy to swap to a WAP. Now when I need to reset my router, etc. it's not a hassle.
One of my concerns with doing any wireless to my media devices was speed, as I occasionally game online and stream 1080p movies. For giggles, I decided to test the speed wireless vs wired. No super science involved. I used an ethernet cable to connect my Macbook directly at the router, turned off my wireless and did a speed test. I then moved the same Macbook to the Apple Airport Express and did the same thing.
The speeds were slightly less, but very minute -- about 95%+ of the original. At the time of testing that meant about 15mb/sec at the WAP I created which is more than sufficient. Since then Cox gave me a free speed bump and I also upgraded to a higher speed plan as well (as I was beginning to hit the max GB limits per month -- due to 1080p streaming I think).
Anyhow, that is probably more than you needed or wanted to know -- but it works well for me. I was pretty doubtful going in this way as in my mind it was inferior. As it turns out I really like it and would prefer to connect this way as there is more flexibility.
mrjaw14
Nashville, TN
Most home router can go in "bridge mode" which essentially turns it into an access point. The AP option is best, router in bridge mode may be cheaper or free if you have one laying around
Denwood
As another recommendation (if you're looking for power) are these Engenius 600 APs : http://www.engeniustech.com/business-networking/indoor-access-points-client-bridges/16598-eap600-new
We're covering 9500 square feet (two floors) with a set (one is for secure internal, the other is for guest access). I've yet to see anything with better reach...and I've got both AP power levels reduced considerably as coverage over our whole site is excellent. They're a bit more spendy at $200, but have been very reliable.
