Wiremold and ceiling fan
pcgold
Saskatchewan, Canada
I have installed a ceiling fan in my garage. It is just plugged in to the same receptacle as the garage door opener. Is there such a thing as a fan control switch that I can use with wiremold? In other words, it's not really hardwired so it won't be recessed into the wall.
BFBOB
Look into wireless fan controls. X-10 devices can do at least the on/off function, maybe speed too. The wireless controls that come with some fans are dedicated, but a little internet searching should come up with universals if there is such a thing.
rburke65
Canfield, Ohio
Is the depth of the wire mold box the issue? And you are just not sure if it will fit into the box? I am not sure if I understand the problem. Is the wire mold box on the ceiling or do you want to mount the wire mold on the wall for the fan control?
P
pcgold
Actually, all of that. I want to mount the fan control on the wall (heck, the ceiling will do too because I will only be accessing it at the beginning and end of winter). I'm not sure if the depth of the box will fit and was wondering if anyone else knew. I have no experience at all with wiremold so don't know if it will fit in a box.
wssix99
Chicago, IL
All of the wireless fan controls I've seen fit in to the box that covers the fan pivot and wrap around the bracket. (So, it doesn't go anywhere inside the actual box and you can use any shallow-type box with the fan.)
