I am about to run three 240V circuits with 10 gauge wire and three 120V circuits with 12 gauge wire around my two-car, attached garage, and I am torn between running the wire from stud to stud and going up, over three studs, and back down. The walls are open but will be insulated and finished, by the way. Every 48" there will be a single 240V receptacle on one side of the stud and a two-gang box for four 120V receptacles (all four on same circuit) on the other side of the stud so as to not put two circuits in the same box. Two and a half walls (including the front wall with 16' overhead door) are 2x4 construction, and the one and a half walls shared with the house are 2x6 construction.
On one hand, if I run the wires from stud to stud, it will pretty much guarantee that nothing will be able to be attached to the wall at that height (give or take a few inches, as I am assuming I will need two holes to get all six wires through) anywhere along the garage walls (and I plan to do French cleats, as this is a woodworking shop and 'maker space'). And when residing the house...couldn't the nails hit the wires? Or not really? Of course, for the interior of the studs, I will use the metal plates.
On the other hand, If I go up and over, it uses a lot more wire, requires more work, requires sealing the hole in the top plate, requires working in the attic, and would mean that anything drilled into the wall at any one of those "every 48" points must be done very, very carefully.
Which would you choose, and why?
