curlysnipe
- Joined
- Apr 27, 2023
- Messages
- 15
I have a Millers Falls bench grinder that I restored. The plug cable was dried out and had exposed wiring. I replaced the toggle switch and the plug cord. I should have taken a photo to remember how the toggle switch and plug cord were wired. I placed the cord black lead (hot) to the motor wire with the red tip and attached them to one pole of the toggle switch. I placed the cord white lead (neutral) to the motor wires with the white lead and attached them to the other pole of the toggle switch. Everything grounded, I plugged the grinder to an extension cord that has an on an off switch. When I flipped the switch on the extension cord the bench grinder immediately started working just fine without me having flipped the toggle switch on the bench grinder to the on position. So I flipped the toggle switch on the grinder the other way and immediately my panel breaker overloaded and flipped to off. I assumed I must have inadvertently direct wired or hot wired the bench grinder. I flipped black and white on the connections and still it behaved the same. I'm scratching my head. Can someone out there tell me what I am doing wrong by looking at the photos I uploaded?
