Wiring a Shop From Scratch
Rocktaco
Colorado
I'll be starting the wiring on my new 22X16X10 shop soon. I've done a good bit of research here and elsewhere, and Ive got some figured out already. I'll be using 100+ lumen per Sq foot using T5's for light.
There will be several 20 recepticals inside and out. At least one 30 amp 220v, maybe more. Other recepticals in areas where I may add a swamp cooler or A/C unit or heater (gas), garage door opener, and two high mounted outside for future patio lighting.
I was curious if I'm missing anything from the obvious, or if anyone has other suggestions based on past experience?
Thanks,
Rock
larry_g
oregon
Welder, lathe, mill, freezer, ceiling recpt for the GDO, wall outlets for the neon signs, box reserved to tie in receptacles located on the front of the bench.
kd3pc
Northern Neck
I was remiss, didn't think I would need it, but will be adding it in the next few decent weather days...
It will be a "box" that looks like an electrical outlet, that has the same vinyl block as an outlet/lamp - but will be used for housing an RF coupling to let me use my ham radio antenna and to test them, as well as a pass through for the solar panel in the yard to charge a battery bank in the garage to run my radios.
Other than that "forgot" your list is better than mine. Best of luck, it sounds like a great one.
