XFIRE
Currently I have 4 8' T-8 fixtures on a 20 amp breaker in the shop. However, there is still a a poorly lit area. I have purchased two more 8' fixtures and want to wire them into the existing circuit. Luckily the current wire ends where I need to add the two new strips. My thinking is to connect the new wire (black to black, white to white) and continue that same pattern to the two new strips.
After researching this, I found that the 20 amp breaker is sufficient to handle the new load. Here is where my question arises. I have installed a pull toggle switch to each of the new fixtures so that they be controlled individually as needed. This will allow me to still be able to turn the original 4 fixtures at the wall switch and control the new lights as needed. What I am unsure of is how to interrupt the hot lead (black?) at the switches so as not to effect the other lighting.
