OldracerJones
I'm trying to wire up my Sears Air Compressor. It's a 240V, single phase with a white, black and green wire coming out of the motor going to the pressure switch box. (See photo 1)
My circuit breaker box (sub-panel) has a 50 amp circuit breaker that is not being used. it's a double pole with white, black and bare copper wires. The bare copper goes to the bus bar and the white and black each come out one side of the breaker (see photo 2).
My compressor is two feet away from the brekaer box so I should not need a disconnect as i can just use the breaker.
I think I need to connect the white from the breaker to the white connector above the white from the motor and the black from the breaker to the black connector above the black wire from the motor. The ground would ground to the screw on the case in the pressure switch box. I would need to mark the white with black tape to show it was hot.
Does this sound right? Can't find any diagrams for any of the Sears stuff.
