I am adding a 50amp sub panel to my existing attached garage. The three car garage has one outlet from the home builder. The previous owner had extension cords and power strips everywhere, but I want to do it right.
I have a couple questions that if anyone could answer would be great.
For rough-in inspection, how do you rough-in outdoor outlets, or lights? I don't want to cut the hole in the wall and have the wire sticking out?
I am planning on running the wiring in the attic, and dropping it down through the walls. I will have to cut access holes in the drywall. Am I correct that I still need to staple the wire to the stud every 4'?
Finally am I allowed to run a conduit through a wall to the sub-panel box? The wall with the subpanel already has insulation since it is the wall against the house. I was thinking of running a conduit pipe down from the attic to the sub panel instead of fishing all the wires through the insulation?
Any tips or suggestions are greatly appreciated.
