nwav8tor
I'm planning on surface mounting numerous twin bulb 4' T8 fixtures in my attached garage. They'll be mounted directly to the ceiling sheetrock and I hope to be able to simply pull the "romex" into each fixture through holes drilled in the sheetrock.
1) Is that acceptable to do without using junction boxes in the attic?
2) If boxes are not required, do I have to use cable clamps at each fixture or can I just staple the wire at the nearest joist (24" o.c.) and use grommets to prevent chaffing where the wire enters the fixture?
Thanks,
Paul
Thanks,
Paul
