Wiring for Auto Hoist
alfacanuck
CANADA
Can anyone tell me how much of a load their auto hoist motor draws? I am wiring my new shop and want to make sure I have an adequate circuit size for this in future.
Thanks, Andy
Stuart in MN
Minneapolis
It depends on the lift. I have a Stinger four post lift in my garage (similar to what you'd get from Backyard Buddy or Eagle) and it just plugs into a standard 15 amp 120 vac outlet. If you know what brand, style, etc. you are planning on, go to their website and see what the specifications are.
Roadster
Chicagoland
Stuart in MN said:
It depends on the lift. I have a Stinger four post lift in my garage... and it just plugs into a standard 15 amp 120 vac outlet.
Same here, but I use it on a 20-amp circuit because it often trips the 15-amp breaker.
DynoDave
I thought most home models offered you the choice of 110 or 220. 110 saves you rewiring if you don't have a 220 available, but is slower. 220 is faster, but of course, requires a 220 line, which not everyone has. Check with the different manufacturers to see.
Steve_S
So Cal
Not that it's a huge difference, but 220V is also more efficient and therefore cheaper to run.
JoeKramer
Long Beach, WA
I just had a Bend-Pak 2 poster installed a few weeks ago. They call for 25A 220V. I put in a 30 amp braker as I could not find a 25A. I think I remember that the surge on start up is 17.5A, and like 9A or so while its running. Them numbers seem to stick in my head.
byrdman
NC
I wired for a future lift using 10/2 (dedicated circuit), it seemed to be enough to handle any lift I might potentially be interested in.
