wiring for mini-split?
Rosco
South Georgia
I am currently wiring my garage for a 220 compressor and a mini split A/C unit. Can I wire the A/C with 10-2 wire (orange) also? Or is ther an advantage of running 8-guage wire. They will be on separate breakers, but just need to get it done before the sheetrock.
I know the A/C unit will also need a shut off at the unit outside.
R
Rosco
South Georgia
Voltage Range
V
208-230V Single Phase
Frequency
Hz
60 Hz
Rated Current
Cooling
A
6.7
Heating
A
6.4
Rated Input
Cooling
W
1550
Heating
W
1500
Net Weight
Indoor Unit
lbs
30.8
Outdoor Unit
lbs
104
Net Dimensions (WxHxD)
Indoor Unit
In
40.5” x 12.3 ” x 8”
Outdoor Unit
in
35.5” x 26 ” x 12 ”
pattenp
Virginia - USA
#10 is rated for 30A which you can have a running amp load up to 24A or 80% on a 30A breaker. So #10 is more than enough if the unit only pulls 7A max. Technically for a dedicated circuit only pulling 7A you could get by with #14w/15A breaker. Doesn't the unit come with a spec sheet that specifies the wiring and breaker size.
R
Rosco
South Georgia
Thanks. I do not have the unit yet, so no spec sheet. Just want everything wired for the future.
What size wire wouls garantee any A/C (up to 24,000 BTU) would work? Just do not want to have to re-do later. Again, thanks!
