Blue Seducer
I am in the process of wiring my garage addition. I have a 100 amp panel in the existing. I was told that I should use 12g solid, which I have used to wire 15 can lights. 10 on one cuircut, and 5 on another with each using a 20 amp breaker. The bulbs are 75 watts. The reason for two cuircuts is to have seperate switches. I discovered that the switches I have are rated 15 amps. Am I ok with these, or should I change them out? Also, what about my outlets? I have not run any of them yet. Keep in mind that this is not a working area, more of a show room. Can I use 12g wire for these with 20 amp breakers, or 14g with 15 amp breaker ?
